Oil Pressure
Discussion in 'The Garage' started by Chevy305, Apr 26, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    So I drove up the highway today for about 3 exits (15mins) and I noticed the oil pressure at the normal 30 lbs, but when I got off the high way and was waiting for the light to change on the off ramp, I noticed my oil pressure fell very low down to like 10. The light changed and I stared driving again, and it went back up to about 25. Under normal conditions at idle the oil pressure is at about 20-25.
    I know my engine is a little tired but does this mean the oil pump is going?
  2. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Check the oil level. I've let an engine get low enough that it affected the pressure. :doah:
    For me it meant I was like a quart and a half low.
  3. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    only need 7 psi per 1k rpm
    yours sounds fine and typical
  4. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    mine was good in my 83. but the sender would leak just a bit. so i replaced it and gained 5 psi per 1k rpm. and thay say 10 psi for every 1k rpm for avarge motor.
  5. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Is it a factroy gauge ? it could be wrong . try a mech gauge instead
  6. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    It is an aftermarket mechanical gauge. So that is normal to allow oil pressure to drop that low? just seems like it should be higher.
    The oil level was just slightly below normal so I put in an oz or two.
    I might have found an oil leak (if that is related) at the rear passengerside between the head and the block, or maybe the intake and block. Not sure but I was going to repalce the intake manifold soon anyway.
  7. FOR MUD
    Apr 6, 2006
    2,801
    387
    Clayton Del
    I was thinking more along the lines of a hand held press gauge [ 0-100 psi ] with a hose and an adaptor threaded into press port it takes the quess work out . 8-10 psi at 800-1000rpm is good . If I rememeber right the oil press is taken from the main bearing , I think??
  8. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    how come the oil pressure on newer cars is more like 40?
  9. Teamstatic2001
    Teamstatic2001 Registered Member
    Dec 24, 2005
    92
    Muskegon, MI
    oil pressure is fine that low getting off the highway, i had a friend with a fresh rebuilt 400 that had a new oilpump no leaks ran 10w-30 and the engine was plastigages when rebuilt when he got off the highway from 70 with a turbo 350 oil pressure was about 15, same with my buddys 2000 5.3 and 98 350
  10. FOR MUD
    Apr 6, 2006
    2,801
    387
    Clayton Del
    what at idle? If so at speed it would be 120psi
  11. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    at normal idle, the gauge reads 20-25 lbs. Normal cruising is like 30ish and it surprised me when I got off the highway to find my oil pressure at about 10. Then when I started driving again it hit about 25 or so.
    The highest I have ever seen the oil pressure was about 50 lbs because it was very cold and I was on the gas very hard at higher rpms. When at running temp maybe 30-35 at most at high rpm.
  12. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
  13. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    mine is always at 60 and about 40 at idle. is that a bad thing :confused: , maybe my guage is bad.
  14. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I'm normally at ~50 psi (fast idle) right after a cold start, 30-40 psi at idle when all warmed up (35-40 idling in P/N, 30-35 idling in gear), and around 45 psi when cruising on the highway at 2,000 rpm @ 70 mph.
  15. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I thought my oil pressure was lower than most. Is a new oil pump a fix for this?
