Oil Pressure
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87K54WD, Aug 16, 2001.
  1. 87K54WD
    87K54WD 1/2 ton status
    Mar 23, 2000
    105
    Texas
    What should the ideal pressure be at idle. Sometimes, I drop just below the 30 mark. FYI: About 83,000 original miles
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Yer good! that's about normal healthy.
    It's been lovely, but I have to scream now.
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    oh yea, well both my k5's run a LOT higher then that... as in 60 when it's cold, and usually just under 80 when it's warmed up good.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    What i've been told as a rule of thumb, is you want 10 psi per 1000 rpm, sooooo.......20psi at 2000 , 30 at 3000 and so on, mine runs about 15-20 at idle when warm and 30-45 at idle when cold, and @ 35 at freeway speed warm and 60 freeway speed cold. so if you have just under 30 at idle warm you're good to go.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
