oil pressure
Discussion in 'The Garage' started by foolhardy, Apr 30, 2007.
  1. foolhardy
    foolhardy Registered Member
    Sep 16, 2004
    84
    i have a 1989 chevy half ton with a 350 what should the oil pressure be im at 25 when im driving and 15 at idle this is with a mechanical gauge. could this be a bad oil pump
  2. NewUser
    NewUser 1/2 ton status
    Feb 13, 2007
    528
    Chattanooga TN
    typical rule of thumb is 10psi for every 1000rpm the engine is running
    my new crate engine with a stock oil pump in it idles in gear at operating temp at 45 psi and pegs out the factory 60psi gauge between 2500-3000 rpm
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    My oil pressure runs a little low for my liking too, but it has never dipped below 10psi.
    Oh wait it did yesterday! :eek1: After about an hour drive up the highway with no overdirve roaring at 3000rpm... My engine is getting pretty tired and needs an oil change so that might be part of it. So for now I threw in some Lucas and now the oil pressure is around 7psi higher than normal. But with normal use, the oil pressure is around 10-15psi at idle and 20-25 while cruising.
    Also what kind of oil do you run in there and what is its viscosity?
  4. dauntless_powered
    dauntless_powered Newbie
    Apr 30, 2007
    Ledyard, Ct
    i run 45 psi all the time
  5. NewUser
    Feb 13, 2007
    528
    Chattanooga TN
    right now im running 20w50 store brand oil and filter in mine but that was only for breakin im going to change it next weekend to Royal Purple Synthetic 10w40 and an AC Delco PF1218 filter
  6. dauntless_powered
    Apr 30, 2007
    Ledyard, Ct
    that 45 psi is with my 305 and 10w30
  7. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    You have plenty of oil pressure.
    And no, low oil pressure isn't generally caused by the pump. Its generally caused by bearing wear.
  8. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    My 95 Grand Cherokee daily driver will Idle at around 10 psi when shes all warmed up, especially toward the end of the oils life. When the oil is cold the pressure is much higher. Since it has over 200K miles on it im not too worried about it. I've used Penzoil high mileage in it since I got it at 135k miles. Every once in a while I put a quart of lucas in it and usually thickens things up to give me higher pressure numbers. I do have to say though, when its hot as h*ll out here in Atlanta and im idlin at a stop light, im always lookin down at that pressure gauge ... hahaha
