oil pressure
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GA89K5, Nov 8, 2001.
  1. GA89K5
    GA89K5 Newbie
    Oct 29, 2001
    4
    GA
    I was out riding my 89 last night and stopped by a friends house. When I got back on the road I notice the oil pressure had dropped almost to 0. I got back to the house and checked the oil and I had plenty. Also, there is a hard knocking underneath somewhere when I take off real hard and sometimes shifting out of first.
  2. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    you drove with no oil pressure?
    man, you'd better hope the gauge is messed or a wire came unplugged....
    sometimes nothing is a real cool hand
    what we have here is a failure to communicate
  3. dyeager535
    26,982
    191
    Hard knocking very well may be just the torque converter bolts loose, or a cracked flex plate. Very common source of "take off" noise. I'd be checking out that 0 oil pressure reading though, before starting it! : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Or spun bearings.......
    What happens if it is in neutral and you hit the throttle?? If it is a double knock then a rod bearing is toast. I would hook up a mechanical oil pressure gauge the next time you start it. If it doesn't register pressure shut it down immediately and tear off the oil pan to take a look at things.
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    0 oil pressure + bad knock = serious problem. Determine exactly what is wrong before you try to drive it any more. Most likely a spun rod bearing.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
