Oil Pressure?
Discussion in '1982-Present GM Diesel' started by 4x4dreamer, Jul 15, 2002.
  1. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    What should the oil pressure be while driving around with my 6.2? Mine creeps up toward the right side of the guage sometimes, then drops back down a little bit. Just wondering. Also, what should the temp be?
    Thanks,
    Eric
  2. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,038
    1,106
    Dallas
    For me, I usually run about 60psi while driving. At hot idle, I'm around 40, and at the first start of the day, it's pegged past 80.
  3. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    Okay, good, so it's not a freak then.
    Thank you,
    Eric
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Mine does the same thing, but it only hits 40 on the long trips when the engine really warms up! My temp runs right at 200 on a normal day! Just got done towing a 1 ton Tractor back to the rental shop and it went up too 210 I think! Nothing major!!!
  5. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    These things might as well be Tanks, they just amaze me. I always thought I wanted a 350, but knowing that this thing will pull through just about anything and get decent mileage, and smell good...who wants a gasser? To move a truck this size, with the aerodynamics of a brick..and still get 20 mpg...SWEET! /forums/images/icons/cool.gif
  6. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    At operating temperature and 2000 rpm, the oil pressure should be 45 psi. At idle, the pressure should be more than 10 psi.
  7. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Somewhere I remember hearing something like "Aerodynamics of a barn...."
  8. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    it's definitely displacing some air as it rolls down the road. We might as well drive backwards for the difference it would make... /forums/images/icons/shocked.gif
  9. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    I,ve installed an ISSPRO mechanical gauge,replacing the bad electrical original sistem,this senders are notorious for going bad.The pressure is about 60 PSI in the first start,when the engine is cold,about 40-45 at 2000rpm,in normal conditions,and 20 at idle,with the engine at 150 degrees.I also have installed a oil pressure switch and a light in the dash.
