Oil psi
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Jul 31, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    i have a rebuilt 350 and the oil pressure always reads about 60 psi, is that normal and if not whats the recomended amount of oil to use
  2. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    More details on this are needed!! 60 psi is a tad high in my opinion but it certainly wont hurt anything. how long ago was it rebuilt? It may still be getting broke in if its not to long ago.
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    My 350 in my "race" truck runs about 45 at idle and well over 60 at cruising rpms.
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    60 is too high...should idle down around 15-30 or so...how recent is the rebuild?
  5. Me89'Jimmy
    Oct 6, 2002
    127
    Sykesville, MD
    its got 25 grand on it so far, it idles around 45 50 but the second i get on the gas it shoots up to sixty /forums/images/graemlins/thumb.gif
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Sound's like a high volume oil pump to me. Or some object is holding the pressure relief valve closed in the pump itself.
    I had that problem with the 454. Installed rebuilt 454 in June, ran at 60 psi. hot, at speed, at idle it had about 40 psi hot.
    Then the first cool night in October, I started it up, and blew the rubber gasket out of the top of the oil filter, twice.
    Pulled pan, oil pump etc. Found a piece of maching debris, just a fleck, holding the pressure releif valve closed. /forums/images/graemlins/eek.gif
  7. o2bjimmy
    o2bjimmy 1/2 ton status
    Jun 19, 2003
    307
    Rapid City, SD
    my oil pres. guage has been at 60 psi since i got it. 60 psi even when its not running /forums/images/graemlins/ignore.gif
  8. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    My 88 runs 60 while driving and 30 while idiling. It has over 100K on it. My other 350, which has about 3K miles idles about 15-20 and runs about 50.
  9. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    when its bouncing off the cam lobes at idle in gear I have about 30psi on the freeway about 70 it will max out at 60psi. I did put some z max in it awhile ago and it gave me 10 more psi.
  10. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    rule of thumb for a motor with some pep, you want 10psi for every 1000rpms you run minimum. redline at 5000rpms, you want 50psi and soforth.
  11. Hustler
    Hustler 1/2 ton status
    May 14, 2001
    326
    St. Peters, MO
    60 psi is not that bad at higher rpms. Now if you have that much psi at an idle, then I might worry a little. It should drop at an idle. Mine is at 60 psi plus when cold and while driving. After it warms up it will drop between 30 and 45 psi at an idle.
  12. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    My 350 was rebuilt as well (at some point prior to me buying it)...when warm, I idle at 30psi, driving I'm around 50-55psi.
  13. dyeager535
    26,980
    If you are using stock gauges, it *is* possible to get the wrong sender. Not sure which does what anymore, but the diesel trucks had different senders/gauges, because they had 80PSI gauges.
    May not be your problem, but the wrong sender for the gauge will cause problems with the reading being inaccurate...it works, just the needle is in the wrong place. Example: A vehicle with a 60 PSI guage with a 60PSI sender, on an engine that puts out 30PSI, reads right in the middle of the gauge. If you put an 80PSI gauge in there without changing the sender, it too will be in the center, but read 40 instead of 30.
    Soo, I guess if you had an 80PSI gauge with a 60PSI sender, indicated oil pressure would always show higher than actual.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't trust an electric gauge. Put a mechanical one on it to find out the truth.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No it didn't. That's simply your imagination. Oil additives are the biggest scam in auto parts today.
  16. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I dunno, JeremyK5 put some Lucas Oil Stabilizer in his Blazer when we were on a semi-road trip and it noticeably increased the pressure. Gauges don't have imaginations.
  17. dyeager535
    26,980
    Read up on them. Electric gauges are every bit as accurate as mechanical when working correctly. Everything loses calibration over time, so judging stock gauges against new mechanical is not a valid argument. (not saying it was used as such, but used vs new doesn't mean the used one is worse when it WAS new)
    Not going to say that mechanical gauges aren't used anymore, but they are certainly much rarer in almost any application I can think of.
  18. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    were does an electrical guage lose calibration? the sender, guage, old wiring, all 3?
  19. dyeager535
    26,980
    Every single component can "lose" calibration.
    From my understanding/playing with these gauges, GM "tuned" them with the ceramic piece on the back of them, to make them as close as possible to correct.
    But, as with anything, corrosion and age will affect readings, although I've never had a gauge that was just "wrong". Broken completely and obviously yes, but "incorrect" (compared to other gauges swapped in) no.
  20. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Electronics lose calibration over time. Here at work in the lab we have to send everything that we use, from stopwatches to thermocouples to pressure sensors over to the metrology lab for calibration. Some pieces of equipment are rated to hold their cal for a year and others are shorter. We even have to send torque wrenches to the metrology lab for calibration /forums/images/graemlins/shocked.gif
