Oil Pump Pickup Height?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ditchdigger, Jun 7, 2003.
  1. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    Hi,
    I have a Big Block Chevy with stock pan.
    I'm installing a Hi-Volume Oil pump and wandering
    how far from the pan I should set it?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I've never buitl a big block, but when I built my small block I simply turned the engine over on the stand so the bottom was facing up. I installed the oil pan pickup in a way so that is was quite a bit too far up, or away from the block. Then I carefully placed the oil pan on the block and that pushed the pickup into the closest distance it could be to the oil pan. Then I removed the oil pan, adjusted the pickup just a little bit more towards the block, maybe 1/2" - 3/4", and that way it.
    The rebuild books have a distance they specify for the pickup to be away from the bottom of the pan.
    -- Mike
  3. Ditchdigger
    Mar 11, 2001
    96
    The Great Midwest
    Hey Thanks!
    I've always gone 3/4" or under, But I'm wandering if
    a Hi-Volume would be different possibly down more in the pan, I've heard of such things as runnin the pan dry in high RPMs with these pumps!
    Anyone else have an idea!
  4. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    It should be between 3/8" & 1/2". Remember to check with the gasket in place or you will have more than desired after assembly.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    yep, 3/8" to a 1/2"...I have mine set a titch under 1/2"....
