Oil pump shaft length
Discussion in 'The Garage' started by GMCLegacy, Jan 13, 2004.
  1. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    does anyone know what the length of a stock oil pump shaft is? overall length, and length from recessed keyway to recessed keyway
  2. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    MSD's site tells you how to measure the distance between the pump and the intake and then measure the distributor. You could probably use my oil pump priming rod and your current shaft to measure up from the oil pump and then measure the distributor.
    http://www.msdignition.com/pdf/85551_85561_8547_dists.pdf
    I bought a couple distributor gears off my friend this morning. Let me know if you want one.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i can find one of the shafts around here if you need measurem,ent of stock one
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I don't know the length offhand, but while perusing the new Summit catalog earlier I noticed that Moroso sells a "short" oil pump shaft that they say is for using a big block oil pump in a small block engine. It's .125 shorter than stock. Is it possible that you got the wrong one by mistake?
  5. wicked jester
    wicked jester 1/2 ton status
    Jan 8, 2004
    139
    CANADA
    I checked a new ARP (for a small block) shaft I had on the shelf in the shop and it measures 6".
  6. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    my oil pump shaftis 6" long. i put the oil pump and distributor back together tonight, everything seems to stack up correctly. thanks for checking
  7. wicked jester
    Jan 8, 2004
    139
    CANADA
    No problem, glad I could help. /forums/images/graemlins/thumb.gif
