oil question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by unick, Dec 30, 2003.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    I was just talking to my brother and he said I should put 7 qts in the engine and 1 in the filter. I thought it was 6 and 1.
    LMK
    Nick
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    it all depends.. my truck has the extra capacity filter, and only takes 5 quarts of oil.. i say fill the filter, then 3.5 quarts in the motor, and check it
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Every small block with a stock pan that I have ever seen or delt with holds 5 quarts total w/filter.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    five total with stock pan, 6 and 8 cylinder engines, i thought everyone knew that gm are 5 quart engines ??
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    My oil changes are drain old oil, put on empty filter, dump in 5.5 quarts and go... 5 is never enough and 6 is too much.
    I use 5.5 and sometimes at about 2000-2500 miles I put in the other half quart.
  6. dyeager535
    26,977
    Yeah, I thought thats what the dipstick was for? I can't understand assuming how much oil your engine should take...do people do the same things with transmissions??
    two "stock" pans side by side
    yeah, I think dumping oil in without (at least the first time, so you know how much it takes) using the dipstick is a good idea. /forums/images/graemlins/rolleyes.gif
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    my 86 305 (bone stock, never had the valve covers off until i pulled them to regasket it at 114,000) takes 6 quarts with the factory recomended oil filter.
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I've been putting oil in this truck for 15 years /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  9. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    My '87 with 305 and the factory oil cooler takes just over 6qts total after an oil change.
  10. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    My '82 takes just under 9 quarts on an oil change. I've got an aftermarket bypass filtration system and cooler installed. I've found that no two engines take the same amount of oil. I train my guys to fill the filter as much as possible before installation and to put the oil level in the add area of the dipstick. Once they run the engine and allow the oil to drain back into the pan after shutdown they top it off. It takes a little longer than the "preset capacities" but tends to eliminate the vehicle coming back to have more oil added.
    I've always thought that checking the oil with a "stick" was a little primitive. Depending on how much the gasket at the top of the stick is worn or if the tube isn't seated properly could have an impact on the final reading.
  11. Confedneck
    Nov 1, 2002
    5,236
    thats why there is the "hashed" area on most dipsticks, or the space between the dots.. to allow for changes in gasket thickness, tube seating, etc..
  12. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    If you think about it, once the gasket gets compressed the oil will be above the hashed "safe zone" on the stick when you fill to "recommended capacities". We send the vehicles out of the shop with the oil levels in the safe zone and within 1/8" of the full mark. It's still operational but as I said, may not be the same as the manufacturer's recommended capacity.
  13. Confedneck
    Nov 1, 2002
    5,236
    within that hash is the reccomended capacities.. if ya think about it, it seems to me that if the amount of oil had to be DEAD ON, everytime, there would be no room for fluctuations within bearing surfaces, gaskets or tubes like you mentioned, and oil would be sold by the vehicle, not the quart.. /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
  14. Confedneck
    Nov 1, 2002
    5,236
  15. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Did you even read my last post? I'm telling you how I do something simple like check the oil. I didn't say it had to be right on the mark but should be pretty close (1/8"). I thought I was pointing out that there are different things that impact the reading on the stick. Sorry if you were taking it personal, that wasn't my intention... /forums/images/graemlins/smile.gif
  16. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    My burby takes 5.5 quarts with a new filter /forums/images/graemlins/thumb.gif
    Overfilling is bad
