oil sae
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1st timer, Dec 30, 2000.
  1. 1st timer
    1st timer Registered Member
    Nov 26, 2000
    27
    florida
    would it be better to use thicker oil if the engine has worn piston rings when it had 50 it did'nt smoke i put 30 in it now it smokes what do you guys think
  2. Rayven90
    Rayven90 Registered Member
    73
    FT Lupton, CO.
    I'm not sure where you live or if yo have fuel injection or not. Be careful if it's cold and you use the thicker oil you could be doing more damage then just letting it smoke a little. Especially if yo have a fuel injected engine.
    Ray
  3. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    if you run the thicker oil in the cold wether you will do more wear on startup, but if your rings are worn that probably means your bearings are worn too so youll be looking at a rebuild soon, so if you dont want the hassle of adding oil often run the thicker stuff, if you want to squeeze a few extra miles out of the motor run the thinner stuff.
