Oil Sending Unit... Need Quick Help!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SAVAGE1, Mar 7, 2002.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I'm bout to fire up the new crate engine and I need to plug in the mechanical sending unit. I still have the stock one in place at the back of the intake manifold. Is there another place I can stick the mechanical sending unit. There's a hole on top of where the oil filter mounts. Can I use that one? Thanks in advance.
  2. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Why can't you use the original hole at the back of the engine? Just take out the stock one.
    David
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    yes you can use the one on top of the oil filter
  4. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    I have two sending units at the back of the manifold joined with a T fitting. One has 3 wires (supposed to be a choke switch/ oil sending unit) and the other only has 1 wire. Can I put the Mec sending unit in place of the 1 wire sensor?
  5. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Cool, that's all I needed to hear. I'm bout to go crank this thing up. Thanks guys.
