oil starvation
Discussion in '1982-Present GM Diesel' started by braunm, Oct 29, 2001.
  1. braunm
    braunm Registered Member
    May 26, 2001
    77
    I was woundering if I get at an bad angle will my truck's oil pump be covered or do I need to worry about this?
    Thanks Mike
  2. braunm
    May 26, 2001
    77
    If so what would be a good way to fix this?
    thanks Mike
  3. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    I had my K5 diesel out this weekend on some steep stuff, and I was keeping a close eye on the pressure gauge. I was surprised to see I never lost oil pressure the entire time I was on the trail.
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I took my Diesel out last weekend to Potosi with the gang on here and my rear main seal stopped leaking. Go figure!!
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    If it wasn't for bad luck I would have no luck at all!!
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I've put some HMMWVs at a pretty good angle, with a eye on the oil pressure guage. Didn't see it drop any. If you're real concerned there is a device known as a "Accusump" that works as a accumilator for pressurized engine oil. 'Think Summit has them.
    Real trucks don't have spark plugs!
