Oil temp guage... Blazer -88
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xswede, Aug 10, 2003.
  1. xswede
    xswede Registered Member
    Aug 10, 2003
    22
    SWEDEN
    The oil-temp guage needle on my Blazer -88 vibrates for about two seconds every once in a while. What could be the cause of this and is it a problem I should worry about? /forums/images/graemlins/1zhelp.gif
    Thanks,
    Dan
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Oil temp? Never seen oil temp. Sounds like something I would like to have. Or maybe would've liked to have had last summer /forums/images/graemlins/crazy.gif
  3. xswede
    Aug 10, 2003
    22
    SWEDEN
    Maybe it's the oil pressure guage then... Yep, that's what I mean... Sorry!
    Dan
  4. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    Well it doesn't sound like your oil pressure sending unit is bad because when mine went bad it just showed zero oil pressure and didn't vibrate. What kinds of readings are you getting from it? Worse case scenario- need new gauge. LMC has them for $55 a peice (part #36-1980). And of course any autoparts store sells oil pressure sending units.
  5. xswede
    Aug 10, 2003
    22
    SWEDEN
    I'm getting normal readings from it, it's just the vibrations every once in a while... Strange!
  6. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    hmm, that might be a sign that your sending unit is going bad. Autozone sells them new for $17. Maybe try replacing it (Autozone lists it as an oil pressure switch) and see what that does. If that doesn't fix it, then I don't know.
  7. dyeager535
    26,982
    191
    Does it fluctuate when the throttle changes? Sounds like it's just random, but my oil pressure gauge really bounces around when throttle position changes. That, coupled with the noise coming from the engine, seems to indicate a loose timing chain.
    Dunno for sure though.
