oil/temp sending units
Discussion in 'The Garage' started by bear76, Apr 5, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    When changing the temp. sending unit do you have to drain the coolant? Same question for the oil pressure sending unit.
  2. dyeager535
    26,982
    191
    Coolant temp will drain, oil pressure will leak some, but not much, essentially all the oil goes back to the pan.
    You can try siphoning coolant out of the radiator, if you get the radiator level lower than the coolant temp sender you may actually get some to drain away from the heads.
  3. bear76
    Oct 16, 2005
    1,065
    here
    Thanks.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    but then again, if you have the new temp sender right next to you, and your quick enough and ready, you can swap them with little coolant loss :D
  5. bear76
    Oct 16, 2005
    1,065
    here
  6. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    I didn't drain either when I replaced them.
