Oil Temp Sensor Installation
Discussion in 'The Garage' started by rcamacho, Nov 29, 2005.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm looking to finally get my oil temp sensor working and will be looking to weld a fitting to the oil pan. Q: I have a wire feed welder running .35 flux. I assume I'll need to convert to gas and .25 wire?
  2. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I succesfully welded the drain plug bung back in the oilpan on my sons '87 Sunbird with .035 fluxcore. I believe it can be done, but it's also an excuse to buy more toys (gas conversion). Practice laying beads on an old oilpan if you can get one.
  3. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    best place to install temp sender is in the cooler line out put from the tranny. this will give you total info on the tranny working temps . as the oil leaves the tranny first then gets cooled and retuns to the pan.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I think he wants an OIL temp reading not a tranny fluid temp. Unless I am reading it wrong.
  5. sweetk30
    Nov 1, 2004
    25,536
    533
    ya know what i think your right. most are doing tranny and i just a$$umed it was tranny. me stupid daaaaa:screwy:
