OIL!!! we all need it.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by '72brett, Jan 28, 2003.
  1. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    hey guys, im hear to let ya in on a little secret of mine.
    If anyone is looking for a great oil (proven best in MANY tests) go to http://www.archeroil.com/ It is a little pricy, but well worth it. I have been using it on and older engine that wasnt in very good shape, when I took it apart, the heads looked like they have been hot-tanked. I sent in a sample for an oil analysis. I dont have the specs for you now, but they were much better than any other oil I have ver used. I have talked with a dealer, and he says there is no better oil. John Deere oil come closest to it on the analysis, but wont beat it. CHECK it out guys. It may save you a lot of hassles some day. Please let me know if any of you are using it now or are interested in using it.
  2. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Although you didn't come out & say that you were a dealer for this oil, it does appear that you are trying to sell your products here. If you want to advertise on CK5, you have to pay the advertising fee.
    http://coloradok5.com/advertise.shtml Click here to see the fees.
  3. '72brett
    Dec 3, 2002
    166
    northwest Iowa
    naw, im 17, I work in a deli part time. I not trying to sell, I could care less if anyone used it. I think its great oil. I just giving the same opportunity to the rest of you.
  4. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Ok then I apologise for jumping to conclusions. I gues if I would have clicked on the link, I could have figured that out.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    mind if I share my opinion? Ok thanks /forums/images/graemlins/thumb.gif
    Oil is one of thoes items I don't spend alot of money on. I don't buy the 79c a qt. cheep stuff eather but I am allways changing my oil so in my opinion as long as the oil gets swapped out regularly it should never be a concern. So Valvaline, Pensoil, Castrol, etc.. work just fine. It's kinda like the sparkplug hype, 6bucks a plug is like...doing what again?? Ya know the Rapid Fire, Split Fire, etc...I'll stick with the 2buck ones and swapum out once a year.
    Sorry just my weak .02c worth.
  7. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I'm with Burt on the oil. If ou change it regularly, there is no need to put in a high-dollar oil, with the exception of manufacturer-specified oils (such as the rather expensive Castrol Syntorq LT that is mandatory for use in the New Venture 4500 and 5600 transmissions or the Mobil-1 that is mandatory in the LS-1 and LS-6).
    That said, the oil with the fewest additives will lubricate the best (ther additives are not what lubricates things, only the oil does that). Excessive amounts of detergents, viscosity improvers, etc. can actually lead to breakdown of the oil.
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    if you want your engine oil to last convert your gasoline engine to natural gas or propane. the gasoline is the major contaminant of engine oil (and heat). it's that little extra gas that seeps in through the piston rings. you can run your same oil on a natural gas powered engine up to 3times as long. correct me if i'm wrong.
    ARQ.
  9. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    Any good sites on changing over to natural gas or propane. Any Hp loss? I've read some sites about it but they seem to be really vauge? (sp?)
    Thanks Shane - /forums/images/graemlins/grin.gif
