oil
Discussion in '1982-Present GM Diesel' started by rich01, Apr 4, 2003.
  1. rich01
    rich01 Registered Member
    Mar 26, 2003
    19
    ATL Ga
    do diesel trucks need need special oil or can you just use oil for normail gas engines?
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Diesel engines must use oil rated for diesel use. The latest rating is CI-4. Usually the diesel oils are rated for both with an "S" and "C" ratings, while gasoline oils usually only carry the "S" ratings. The "C" stands for compression ignition (diesel) and the "S" stands for spark ignition (gasoline). Look for the ratings in the little API circle or on the back of the bottles. A lot of people, including myself, like to use Shell Rotella T 15W-40 oil. It's designed for diesel engines, comes in handy 1 gallon containers, and is available at Wal-Mart.
    Casey
  3. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    yea i use Penzoil 15w-40 Heavy Duty, $21 bucks a case!! good stuff
  4. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i prefer Delo 400. it is also 15w-40. its failry cheap, availible and costco and walmart by the case.
  5. DieselFreak
    DieselFreak Registered Member
    Mar 13, 2003
    71
    Aaland, Finland
    dunno what mark it is but i'm using an SA3 10W-30 oil due to the large temperature differences here. Last winter it was -20 degrees (centigrade) here. On the other hand, in the summer it can be up to +25 degrees (centigrade)
    <font color="purple">Drive a diesel - Be happy</font>
    /forums/images/graemlins/k5.gif <font color="red">DieselFreak</font> /forums/images/graemlins/k5.gif
