Oilpan problem
Discussion in 'The Garage' started by outlawtorn, Dec 10, 2005.
  1. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    Im actually kind of embarrased to ask this but aaaa... what should a guy do if his oil pan will not come off?:crazy: Ive tryed claw hammers, a shovel handle ramming it, screwdrivers, prybars.... this thing will not come off. I actually bent my framing hammer prying between the oil pan and starter lol:haha:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Step 1.
    Remove bolts
    J/K
    :haha::haha::haha:
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
  4. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    good idea dan, im gonna run in town and grab some of that stuff:p:
  5. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    Nevermind not good idea dan:crazy: I bought a can, used almost the entire can on it... i mean i just freaking drenched it with that and let it sit for a half hour. I just got done prying/beating on it again, to no avail. :rolleyes: This sucks, anymore suggestions guys?
  6. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    You sure you have all the bolts out? Theres a 7/16" bolt at the 4corners. Try taking a rubber mallet and hitting it against the side of the pan. Dont do it to hard but a good blow willbreak the seal on the side and then you can pull it down to seperate from the other side. Good luck
  7. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    yea they are all out lol, ive been beating on it with hammers and ****... its not moving at all... i gave up a few hours ago lol.
  8. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Try an ounce of C4:haha: :haha: :haha: :haha: :haha:
    JK,
    Dan..
  9. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    putty knife and a hammer!! (after a couple beers - for additional strength):D
  10. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    tried the puttyknife routine,,,,, im starting to wonder if i used jb weld instead of rtv:haha:
  11. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    did you pullthe inspection cover off the trans and get the 2 bolts tucked away up there
  12. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    yea i had all the bolts off... i finally got it off today.... i used the entire can of that gasket remover on it and let it sit overnight. I went and grabed the biggest hammer i had and the smallest screw driver i owned and just hammer the piss out of it. Broke the front lose enought to fit the claws of my hammer and and pryed on it hard and pop, she came off.
  13. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Must have been held on with Indian head....That stuff doesn't know when to give up.
  14. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
