OK, alot of work to keep it weather tight but here UPDATED. PICS
Discussion in 'The Garage' started by cybrfire, May 27, 2004.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Just a little shorter than it used to be but now I can narrow the tail and still be weather tight which was always a must for my project.
  2. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    Re: OK, alot of work to keep it weather tight but here is a peice. PICS
    how do ypu plan to narrow the rear?? like this | | or \ /? looks like you cut the top to fit | |..
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    it will be narrowed like this \ / but it will start behind the shortened top and wall that I've yet to build. If only I lived in warmer climates I could have skipped alot of this. Basically I wanted to be able to wheel it in the winter yet and take the kids along so 4 seats inside was a must as well.
  4. BOWTIE
    Dec 28, 2000
    2,018
    ahh i see, cool idea!!
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I don't forsee any major snags. It won't narrow as far though considering I have a shorter span to do the narrowing but I think it should still go as far as the front or close.
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Will you make a wall so it goes all the way to the floor at the back? Looks like a good idea /forums/images/graemlins/thumb.gif
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Yeah, there will be a wall that basically would simulate what the tail gate used to be. Probably inch tube frame with 18 ga. on each side with some sound deadening inside. I think I will use plexi or lexan for the rear window. It won't go up and down anymore but don't really need it to. Top is light enough now I can remove it by myself so I won't have to dread removing it and then putting it back.
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Looks familiar
    My narrowing behind my half cab on my old K5. Ugh once you cut you just can't stop.... Been getting tempted to narrow the new one, and I haven't even trimmed the fenders yet. The only thing is, I wasn't planning on running a sealed up top with the narrowed rear, how do you plan on running your cage through the top? or are you not going to run bars down to the back?
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    There will be bars in the back probably like door bars except going backwards from the main hoop. then x braced in front of the rear wall. Then some tubes will go through the back wall as high as possible yet still under the window and turn down to the frame. This is where my radiator will sit inbetween and under these bars and the spare will be on top of the cage bolted down. Started fabbing the rear wall today. It's a little more complicated trying to keep the top removable. I think when the top comes off the glass will come out with it. If you wanted to just remove the glass/lexan I will have to remove the top or at least take it loose and slide the window out of its track.
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    In the winter when me and my dad were going to weld a piece in to strengthen the rear by the tailgate, we made a wall thing out of plywood, and used a spare furd rear window on it. So it basically would have looked like a short box if the plywood was painted to match. It didn't keep water out though /forums/images/graemlins/doah.gif
    Your idea seems very interesting, make sure to post pics of the process /forums/images/graemlins/waytogo.gif
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    OK, here some progress photos.
    Needs some weather stripping yet.
    Should be able to get the wall skinned out and sealed up tomorrow. Then I can figure out the window. Thinking about some kind of flush mount setup. Haven't really made up my mind yet.
  12. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    That is so beautiful
  13. BOWTIE
    Dec 28, 2000
    2,018
    nice work, bro!! /forums/images/graemlins/thumb.gif
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Thanks. Took alot longer to do the top than I had anticipated. Body work sucks. Once the wall is skinned I can start the rear narrowing. Won't be long now /forums/images/graemlins/woot.gif
  15. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    man your K5 is AWSOME!! I love the look of that truck!
  16. JRS2 75K5
    JRS2 75K5 Registered Member
    Dec 6, 2001
    40
    Central Missouri
    I saw one done similar to yours but the guy modified the old tailgate with the power window for the bulkhead. It did not look like much more work than where you are at now and he was able to have the rear window up or down using stock parts. His bulk head was a little closer to the original cab?? The top you have made looks great!!
  17. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I had considered doing that with the tail gate but one of my main goals is dumping weight and that tailgate just has to go. /forums/images/graemlins/hack.gif
  18. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    How small are your kids? The back seat in Wimpy is half way back the bed? I guess I'm askin where are ya puttin the back seat?
    By the way, that's some excellent fab work you're doin. /forums/images/graemlins/peace.gif Wish I had the time and money at the same time to do stuff like that.
    Good luck to y'all in the future.
    Allan
  19. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The back seat will be two seperate seats facing the center of the truck for leg room. I have roughly 28" of space between the back of the front seats and the rear wall. I have some really slick seat brackets located. The seat automatically springs back up when not in use. They also come with their own seat belt installed so they should work nicely. When the kids aren't in the back they are up out of the way.
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    nice mower shed
