Ok answer this
Discussion in 'Communication (CB | GPS | HAM)' started by Peeetah, Mar 15, 2001.
  1. Peeetah
    Peeetah Registered Member
    Jul 3, 2000
    97
    Mt. View, CA
    I mounted a antenna on my quater panel. Origionall I had a four foot FirestickII and It worked perfectly. Unfortunantly the wieght of the fiberglass antenna was to great and it caused to much flex on my quarter. I then purches a 5 foot regular antenna and hooked it up to a swr meter. After cutting about 6 inches off it the best reading I could get was 2.3:1 ratio. I now only transmit at 70% on channel 1 and full power only on chaneels 36,37,38,39,40? Why is this? Do I need to make it longer, shorter?
  2. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    heres just a suggestion, mount it off the bumper.
    thats what i did and it works great. i took some steel, cut it off, used the holes in the bottom of the bumper put it in right ther, oh yeah i also painted it.
    here a pic [i hope it works!!!]
    if it didnt work then theres a pic on the pictures part of my webpage [url in signature]
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You might need a better ground. K40 and Firestik also make antennas that have adjustable tips, just turn them to adjust. I prefer K40 though. Never tried Wilson. I also have an 18' Shakespeare base station antenna and it rocks!
  4. OhioJimmy
    OhioJimmy Registered Member
    Jun 21, 2000
    92
    just moved to Kansas, Hoisington
    whats the lenght of your coax, 18 feet is the perfect length according to several cb shops I've visited, I've also always been told that if your swrs are too high that it will harm your radio and as you said rob power. Did shortening you antenna affect your swr reading? if so did it go up or down. you might be able to shorten a little more and get it in spec.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Why did you cut the end off? IS this an all metal ant? Check the ground and coax length.. If all is good, get a Wilson Fiberglass ant.. They have an adjustable tip oon the end to aid in adjusting the SWR.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
