ok guys... 411 on cage / frame tie-ins
Discussion in 'The Garage' started by TXsizeK5, Sep 17, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I'm getting closer and closer to having my cage made... I want 2 parts in the rear to bolt to the fender wells kinda like a rolls bar and 4 points in the cab to tie in to the frame. My friend said the cage should be removable for ease and I need some sort of bushing and that its not good to directly bolt or weld? Give me the 411 and pics of your tie ins!
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    well, i have yet to start mine for MANY reasons. but thats another post. im going to use the 6 body mount bolts in the bed and build a square tube frame for the bottom of the bed. it will extend out to the corners of the bed and be hard mounted into the new rocker knockers. im doing a 10 point cage that will include my dash board. this way once i trash this body one of two things can happen. i can remove the cage fairly easily and slide it into a new body, or i can remove the cage and re mount it to the frame for a tube buggy start.
    Grant
