ok guys im still having problems with my 85 when i go up hills
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cootersk5, Sep 4, 2004.
  1. cootersk5
    cootersk5 Registered Member
    Aug 12, 2004
    48
    Frederick Maryland
    ok heres the story i bought an 85 blazer from a guy. dont ask me why but he put a 307 in it. well thatcame out and i bought a 350 from advance auto parts. i went through three engines i finally got one that didnt mess up some how. now heres my problem
    when im going up a hill and the tramission needs to downshift to get more power and then kicks back up a gear the truck kicking and bucking and acting like its flooding itsself or something. at first i thought it was my holley carb because the engine had blow back through it so i thought i had blown the power valve or what ever is in those that go all the time. so i put my edlebrock 600 on it and it was fine for about half the day and then started doing it again. so what do u all think. maybe the spark isgetting drowned out or the timing of a little off i dont know please help /forums/images/graemlins/grind.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Make sure that the fuel filter is clean. If the carb doesn't get enough fuel to keep the bowls full then it will start to buck under heavy loads. /forums/images/graemlins/frown.gif
  3. cootersk5
    Aug 12, 2004
    48
    Frederick Maryland
    thanks i didnt even think of that /forums/images/graemlins/grind.gif
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Had the same problem once with my 87- Fuel filter was clogged beyond belief. Replaced it and I reached a top speed of 107. /forums/images/graemlins/whistling.gif
  5. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Maybe even it could be the carb. My street carb hates anything off camber and will flood out and strand me and I have to ride the skinny pedal and the brake to make it over an obstacle so I am going to put the Q Jet back on it and be done with it, or atleast until I find a nice TPI set up.
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Had the same problem with my Edlebrock carb and installed "spring loaded float needles" and never had another off camber problem. /forums/images/graemlins/waytogo.gif
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What tranny , if you are running the 4 speed auto , and chances are it came with highway gears , no carb will fix that . Just leave it in 3rd , or manually downshift , and deal with it sucking on hills until you get lower gears in the axles . The tranny is probably downshifting , gaining some speed , and upshifting again , then you lose momentum and it kicks down again .
    Just a thought /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    right on, lower gears are your answer.
