ok guys need help - quickly if possible - trying to crank new engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Apr 15, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    OK guys...
    I am assuming that I have a wire hooked up incorrectly somewhere, but I'm not sure where. when I hit the key to turn it over nothing happens.
    where do I start, and what could possibly be wrong?
    oh yea, and the battery is hooked up /forums/images/icons/wink.gif one cable off the + side of the battery goes to the alt, and another goes to the starter. then the - side of the battery goes to the frame, and ground a few other places.
    starter has 2 wires that go to it from the wiring harness; one I connected on the same post as the cable from the starter, and the other one goes to the right from it.
  2. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    It sounds like either ignition or starter solonoid. You can take a piece of wire, or wrench, and short the positive wire (from the battery) to the smaller post on the starter and it should kick the solonioid in. You will hear it click and the starter should turn. You can also disconnect the wire from the ignition (small one on the starter) and put a test light on it. It should go 12v+ with the turn of the key (start position). Hope this helps. See where that gets you.
  3. tacoma972
    tacoma972 1/2 ton status
    Jan 6, 2002
    114
    West Point, Ga.
    check the little wire and be sure that you have the wire connected to the drivers side post and not the passenger side.
  4. Overkill
    Jan 15, 2002
    284
    Orlando, Florida
    Might also want to check the neutral safety switch. Its located at the base of the steering column (by the fire wall). You can pull the connector off the switch and short the wires together with a paper clip or piece of wire. If it is the switch this will allow it to crank. Just another thought.
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Put a meter on the purple wire (right terminal looking from the front) and have someone turn the key- you should have 11.5 12.5 or so volts when the key is in the start position. If so turn key off and meter between the large 4-1/0 ga cable attached to the starter and ground- you should have battery voltage. Try that and see what you get.
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Damn, I can't type as fast as you guys/forums/images/icons/laugh.gif. Excellent point on the safety switch Overkill! I totally forgot about that, as I have both of my trucks bypassed/forums/images/icons/wink.gif
  7. Overkill
    Jan 15, 2002
    284
    Orlando, Florida
    LOL, I just did mine about 2 weeks ago. I think that should be the first thing to do to any offroad rig! Just helps simplify things a bit. hehe.
  8. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    LOL - well I checked all of above, and finally figured out it was a ground problem /forums/images/icons/blush.gif anyway I'm working on timing the stupid thing so I can start it & do the cam break in! /forums/images/icons/cool.gif
    took a little break to grab a bite to eat, and to let the battery recharge /forums/images/icons/crazy.gif I'll keep ya posted, but this thing should be started pretty quickly.
    I do have one oil leak I am going to have to fix, and that is the computer sender. I will have to take the distributor off to fix it so I'll probably tackle that as soon as I eat.
