OK, help me decide here
Discussion in 'Center Of Gravity' started by cybrfire, May 2, 2004.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Considering narrowing the front and rear of my blazer like has been done before. One of my biggest hangups about doing this is, I want to take my three sons wheeeling with me. Of course keeping the rear seat is out of the question on a narrowing job. I have come up with a solution that allows keeping rear seats. They would be more like those little s10 rear seats that face inwards. Ok for kids not so good for adults. I sit here pondering the pros and cons of the whole mod. What are some of the good things about this and what didn't you like about it? I guess overall I'm after less weight, being able to lower it more in the future. As an accumulative effect easier towing and pulling.
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Why not get two of these, they bolt flat down, so you bolt them to the floor and they are setup for a 5 point harness.
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Just add another regular seat in the rear. Call it a 3 seater! I'm narrowing the f/r on my blazer one day...
    Pros are less sheet metal for rocks, you can see better, less weight.
    Cons are battery location in engine comparment. Would it be legal?
    I can't wait to do mine... time will tell me when /forums/images/graemlins/dunno.gif
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Yeah I was thinking about using something like those. Still would want to face them toward the middle so they could be positioned close to the front seats yet still allow leg room.
    I think I'm gona do it just holding back yet. Right now I don't have any engine trans or tcase in. It would be easier to do now probably. Got some new carpet that would have to go. Battery box that may have to be reconfigured for smaller interior space. Since I'm dumping weight, I have a CB that could go and a bearcat scanner as well.
    Anybody that has done this, Did you have to dump the factory heater?
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would just use a jeep rear seat. /forums/images/graemlins/whistling.gif
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I used 2 of those Summit Poly seats with Corbeau harnesses and mounted them to a removable frame (clamps into the roll cage). Works great and light weight. And I can remove them for extra room when they are not needed. I also put my battery under the back seats, inside the frame rails.
  7. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    A buddy of mine used the seats out of the bed of an Isuzu Brat to put in the back of his buggy for his kids. They fit the truck, fit the kids and came with oh [darn] bars built right in.
    It might not work for you but it’s something to think about. /forums/images/graemlins/thumb.gif
  8. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i have a rear yj fold and tumble seat that i was going to use for mine, but with the factory rear seat having seat belts i decided to keep it instead. you can still keep the rear seat it just depends on how much you taper the rear.
    i could've prolly kept all the heater stuff when i did my front, but i went ahead and yanked it out since the rig will be completely open anyways..
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Well I'm gona do it. Also dropping 4" of lift at the same time. I'll probably end up tapering it as much as I can and keep the heater. Gona do a partition and build a half soft top for it as well. That way I can still bomb around in the snow without having to wear a snowmobile suit.
    First got to find rear 4" springs. Need two sets.
    I work for a place that builds rescue trucks and they have some really slick seat mounts that are small and when you aren't in them they fold up automatically. Spring loaded. I think they will be just right. If not them some of those cheap summit seats bolted to the roll cage.
  10. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    When I did the S-Blazer body, I had to modify the floor below the rear seat to clear the fullsize frame. So I built a storage box into the floor. I needed a flip and fold seat to access the box, and I refused to use a Heep seat. I found Mitsu. Montero/Dodge Raider rear seats worked well, as do Isuzu Trooper (from the 80's) seats are nice for the application you are thinking.
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    thanks. I'll keep those in mind. did they come in black?
