Ok, how about this noise?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MadIrish, Sep 26, 2001.
  1. MadIrish
    MadIrish Registered Member
    Aug 13, 2001
    48
    South Carolina
    It is more obvious when going about 25. It seems to be a slower rpm sound than the average workings of the drivetrain. It sounds like somone walking on a treadmill under my floorboard. I am hoping I am just hearing my spedo cable or somehting like that but I have a bad feeling it is tranny related. Does this sound familiar at all? It seems to stop when I come to a stop if that helps.
    *******82 K5 All stock but wheels and tires, 305 4bbl, tranny? NP208*******
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    rear u-joint about to go out? Loose or bent drive shaft....kinda like a tapping sound? Tranny problems are usually more noticable in shifts or shifts that never happen....is it from beneath you or further back?
    What? You think the hole is too deep? Lemme see...
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  3. Grim-Reaper
    7,385
    Atlanta
    Muffler bearings.
    You got oil and ATF in the Diff and Case?
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  4. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    is it a rubbing sound or grinding sound could be bearrings
    Brian
    83 K-5 4" on 33's
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Muffler Bearings... thats a good one!
    What, Me Worry?
    <a target="_blank" href=http://www.echobit.com:81/k5/> The 'BEFORE' pictures</a>
  6. MadIrish
    Aug 13, 2001
    48
    South Carolina
    Muffler bearing, nope, I checked those. And my Flux Capasitor is fulxin like a mofo!
    Is kind of a constant very light metal grinding sound. Alot like someone running on a treadmill. A constant pitch with a stronger bip about every half second moving about 25.
    **It seems to be coming out right at the tranny hump.
    **I havent checked my diff yet. I need to do that.
    **I have a blown seal between the tranny and xcase
    **I just got both the rear ujoints replaced. They were totaly trashed. A few joints had obliterated needle bearings and one was dried up and rusted.
    The front driveshaft only moves when 4wd is enguaged right?
    Man, I need a tape recorder! :)
    Thanks for all the tips so far!
