OK...How do I.......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MrBob, Jul 31, 2000.
  1. MrBob
    MrBob Registered Member
    Jul 27, 2000
    52
    Take the back top off the 86 K5 Blazer?? Bryan (the proud 16 year old owner) took all the bolts out and tried to lift the top off (What a heavy son of a gun that is) and the back at the tailgate remained strongly attached...How do you get it off?? does it slide into a couple of slots in the bed side and you have to push it back out of the slots or what? Ours has been attached so long the rubber was rotted so instead of risking a leak we abandoned the removal until we could get new rubber and advice on removal.
    Red Springs, N.C.
    "I ain't responsible for my crappy typin' or spellin'"
  2. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    there are two more bolts way at the back behind the panels.
    Knife.
    knife.coloradok5.com
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Also, after you remove those 2 bolts, you might have to stand in the middle and push up with you legs while your back is on the top. I had to do this with mine to break the seal.
    89 K5 Silverado
    http://mudfrog.coloradok5.com
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    soak the seal with plenty of armor all or soap or you will be at the dealer, bent over for a month...
    <font color=blue>Espen88k5 at:http://www.espen.coloradok5.com</font color=blue>
  5. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah, there are two hidden security torx bolts right behind the panels, I would replace them with regular hex head bolts.
    YEEEEE HAWWWWW[​IMG]
  7. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    If you plan to take the top off more often, then I wouldnt even put those back in. I never put those in, I also skip just about every other bolt. Havent had a leak yet. Good Luck
    BlazerBoy
    http://generalblueballs.coloradok5.com
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    You have to take the interior panels off to get to the other 4 bolts
    90K5
  9. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    And dont forget the rear dome light connector. It's on the driver's side, in front of the window, behind a little panel.
    You probably knew that, but just in case.....
  10. MrBob
    Jul 27, 2000
    52
    Thanks, ya'll, appreciate it!
    Red Springs, N.C.
