Ok how to store Drive shafts and axle shafts spares.
Discussion in 'The Garage' started by Grim-Reaper, Aug 20, 2003.
  1. Grim-Reaper
    7,385
    Atlanta
    Ok I want to get my trail spares out of my storage box and permently mounted.
    First thing I need to do is come up with a way to keep splines, bearing and seal surfaces from rusting. I'm thinking of a thin coat of paint and take my chances of the paint hurting the bearings and seals.
    Next question is where to mount them. I figured some sort of bracket and radiator clamps and bolt it into the sides of the bed. Anybody do this and have some pictures to share?
    I think my spare tie rod is going under the truck. I'm leary of this location for tha axle shafts because of the amount of crud I would have to clean off before using them. Drive shafts a little of the same concern because of the U-joints.
    Pros and cons?
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    What about in a piece of PVC pipe with caps on the ends. Maybe seal it with some silicon caucking from the outside os it could be cut with a knife? Throw a light coat of oil on it before you put it in there. Maybe some desicant too.
    Kris
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Out here in AZ I see alot of axleshafts stored under the truck. But back east with all the mud and crap it might not be the ideal spot for unprotected storage. Driveshafts and such you could mount to a rollcage and axleshafts might be stored well under the hood somewhere. I personally have mine inside my truck behind the spare tires, but that is temporary until I get time to mount them somewhere better.
    I put a coat of spray paint on my spare axles. I figure a little spray paint on the bearings is better then having rust, dirt, or corrosion on them.
    Harley
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i say put the tire rod under the truck and the PVC pipe up on the roof (if present) or up under the lip of the bed. put a decent film of bearing grease on the caps to keep out moisture though.
  5. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i second the pvc idea. /forums/images/graemlins/thumb.gif
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Paint is good and so is a light coat of grease. I like to use hoseclamps to keep stuff hung below my bed rails.
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I can't find anything when I need too, But somewhere I saw a pic of the PVC thing, and it looked like a slick set up....
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I carry front shafts in a piece of pvc pipe.I also have a complete front drive shaft hooked to the side of the frame using some brackets I made.Ive been thinkin of putting my spare tie rod underneath somewhere too.But I dont do mud so I can put just about what ever I want under there /forums/images/graemlins/thumb.gif
    Crapy pic but my HiLift and pvc pipe with my axle shafts are right above the spring hanger /forums/images/graemlins/grin.gif
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> How about getting a can of that plasti-dip stuff that you use for tool handles and dipping the splines in it? The stuff peels right off when it's dry and will keep any contaminants out of the splines, so when you need the spare just peel it off and you'll have nice clean splines. /forums/images/graemlins/thumb.gif </font>
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm planning PVC between the rails for my spare D60s complete shafts. Should be able to get both in one tube along with the spare hubs and cap the ends. I've got the Spicer anti-corosion papers that came on the new shafts to wrap around them to store. Also, look for spray cosmoline, good stuff for storing parts like that.
  11. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    That's the pic I was talking about....
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I don't have pics, but a buddy of mine put all his long stuff like that under his blazer. Now he had a 2" body lift tho.
    What he did was cut an access hole in the floor of his bed, welded in a box to the underside of the floor, and hinged and reinforced the piece he cut out for the access door. Works really slick and everything stays dry and clean and has more room inside for tools and stuff /forums/images/graemlins/thumb.gif
  13. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Well, when I was carrying them, the long tie rod and the long inner 44 axle shaft (with stub and ujoint) I kept zip tied to the seat mounting brackets behind the front seat. It was quick, it fit, it was out of the way and I used electrical tape to wrap the ends of the splines to keep them clean and rust free.
    Depdog
  14. Storm Trooper
    Nov 24, 2000
    4,640
  15. Grim-Reaper
    7,385
    Atlanta
    That is what I was thinking is something like that. I dont know if I like the PVC pipe for a couple reasons. Those parts get sliding around they are going to make noise and possibly bust the PVC. Where I want to mount the shaft I may not be able to get the long shaft into the pipe because of the set back on the side walls to the gate (no interrior pannels)
    How about rear axle shafts for a 12 bolt? That's the one I'm really perplexed on because of the wheel flange.
  16. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    bubble wrap. /forums/images/graemlins/smile.gif I've tried it for .. umm. other delicate items, and it worked fine, didnt bust through the PVC. PVC's really only bust through from extreme sharp external impacts, and any impacts to the edge. The thicker stuff is the one you want.
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I usually pack things like that with grease rags to stop the movement. Then, when I pull it out to install, I have plenty on hand.
