Ok I changed my oil and noticed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Jul 7, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I changes the oil in my truck yesterday and I noticed that there is a hole in the in the transmission it right next to the oil pan. It looks like there is fluid coming out of it. And then I look back at the front of the drive shaft and it looks liek there is fluid that has come out its on the bottom of my truck on the drive shaft and the tranny. Does anyone have a clue what it is ????
    And how to fix it?
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    There is a drain hole in the fly wheel cover. It sounds like that may be what you are looking at because it is right next to the oil pan. As for the leak it sounds like the input shaft seal in the tranny. Mine is doing the exact same thing. The Tranny fluid going down the front shaft could be the T-case seal too.
    Brent
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Sounds like either your front main tranny seal is bad or your torque converter is leaking (not good).
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Same thing happens to the torque convertor as the damper. The seal gets hard over time and will wear the torque convertor and cause a leak. I believe you can get a repair sleeve for the convertors too if I'm not mistaken.
  5. COOTER
    COOTER Registered Member
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    if that seal to the tcase is bad replace it quick cause the fluid thats supposed to be in the tranny will go into the tcase and youl burn up your tranny.
  6. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok so what do I need to change the seals then? How hard is it to do? Will I need to take the trannsmission out? will I need to jack the truck up? Or will I be able to lay on my back and change it from there???
    Thanks Brian
  7. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    Gonna have to drop the tranny and pull the torque converter off, and look at the seal on the converter and the tranny input shaft, see which one is leaking. Good luck.
  8. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    He shouldn't have to worry about the transfer case because his NP208 runs on ATF also.
