OK I guess I'll get a lockright for the front.... videos
Discussion in 'The Garage' started by jjlaughner, Mar 20, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK I guess I\'ll get a lockright for the front.... videos
    clicky ... then do the right click "save target as" on the videos and let me know what you think! /forums/images/graemlins/ears.gif
    Lockright for 10bolt front $288?
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Re: OK I guess I\'ll get a lockright for the front.... videos
    Don't know the price, but looks like they work from the video /forums/images/graemlins/rotfl.gif/forums/images/graemlins/waytogo.gif
  3. 81sb
    81sb Registered Member
    Sep 26, 2002
    14
    Saskatchewan Canada
    I just installed the lockright in my 12 bolt rear this morning. Got it for $200 even from Jegs. Only got a chance to try it out on the ice and snow on the streets but it seems to have made quite a difference.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    2 things i noticed about the videos... the old Ford made it across so easily, but did you happen to notice how much faster he hit the rollers than the other trucks? considerably faster. also, with the "Trans Am" and its open diff... there is no such animal. a Trans Am is the high performance model, therefore it gets all the goodies. traction devices included. i have never seen a 93+ TA with an open diff.
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Lock Right Automatic Positive Locking Differential - GM 10 Bolt (28 Spline)
    Item # 754-1920 1 x $195.99
    Lock Right Automatic Positive Locking Differential - GM 14 Bolt (10.5"Gear, 30-Spline)
    Item # 754-1955 1 x $207.99
    Order Total: $403.98 plus shipping /forums/images/graemlins/waytogo.gif
    Once I get a job I'll have to order this!
    Hows the snap crackle and pop going around corners? /forums/images/graemlins/ears.gif
  6. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    No noise to be heard out of mine.
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Are limited slips REALLY that useless??? /forums/images/graemlins/confused.gif
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    yes they are.
  9. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Loose ones are. You can stick 800lb springs in them so when tooling around in your f-body you get to listen to your tires squeal when going around corners.
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I hope not... /forums/images/graemlins/confused.gif
    I like the auburn in my truck but thinking about snow and playing I've been told that I had one tire in the front and one tire in the back snipping when I got highcentered /forums/images/graemlins/ignore.gif
    On dry payment I have no problems breaking both tires loose /forums/images/graemlins/dunno.gif
    Anyone play in the snow, or drive on the highway in the snow with a lockright? /forums/images/graemlins/ears.gif
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Yeap. Rear, don't even know it's there. Front, it blows donkeys in July.
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    so you run lockrights front and rear... what about whenthe front end is unlocked and your in 2wd? Is the front still a problem?
  13. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    As long as you have locking hubs up front you will never notice the lockright on the street. It is effectively disconnected, even if you are in 4 wheel drive until the hubs are locked.
    I run a lockright front and I like it. No problems as of yet. I only have a few runs on it but it is fine. I ran my truck in the snow in Colorado 2 winters ago. With the welded rear I never needed 4x4 in normal snow. The only time I used 4x4 was in 30+" of snow during the blizzard. In snow that deep you want dual lockers anyway.
    Harley
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Since if you've got your hubs unlocked and your transfer case in 2wd there is nothing moving you won't even notice the locker.
    However, it is common practice where it snows a lot (like around here, 300" per season) to leave your hubs locked for extended periods of time and just run 4wd as needed.
    This causes the axleshafts to rotate which in turn causes the front driveshaft to spin. The steering with the locker in the front is heavier than with an open differential. I'm not entirely sure why. Furthermore, if you turn full lock around a corner chances are the locker is going to engage and you'll feel and hear a "bang".
    While running in 4wd with the hubs locked there is quite a bit of bind in the system unless it is really slippery out. For example, when I'm driving down the road when it is mildly slippery in 4wd I can have my steering wheel up to 3/8ths of a turn trying to fight the truck to keep it going straight. Then when it gets slippery and the bind is let loose the truck jerks in the direction you had the steering wheel pointed and you scare the people next to you because you suddenly lurched at them. Most people will tell you that if they've got front and rear lockers they can have their steering wheel turned 1/4 turn either direction and it has no bearing on where they go.
    However, when it's really slippery out nothing beats that front locker. If you think a Talon TSi or Lancer Evolution launches hard, you've never been in a locked truck. I've been stuck in a snowbank (my own doing) and I got one front tire to contact the ground and it pulled me out. I was pretty far up in the snowbank with all four tires off the ground. I dug under the front of the truck until it dropped down and then let the locker in the front pull me out.
    Running in 4wd with the hubs unlocked is a good way to ruin hubs.
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I was 100% sold on running a lockright in both rigs till I just read this /forums/images/graemlins/thinking.gif I guess the daily driver (99% street rig) will stay open front/auburn rear, the project truck will probley get a lockright in the front and rear though /forums/images/graemlins/thinking.gif It will see street use cruising to and from locations, including some summer cruises down the strip with the top off /forums/images/graemlins/waytogo.gif
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'd go LockRight in the rear and clutch-type limited-slip in the front. In fact, if I'm ever to have another daily driver/woods-ready vehicle that's what I'll do. Auburns and their loose cones are like a condom, use it once and throw it away. The only Auburns I've ever seen in action will allow that "loose" tire to spin madly. For example, If you were to put one tire on gravel and one tire on asphalt you'd never break the asphalt tire loose but the gravel tire would spin madly. Sure, it's still 10x better than open but it pales in comparison to a locker.
    I don't even notice the rear locker. It's predictable unlike the Detroits I've driven. It'll stay unlocked even if I roll the throttle on like you would through a left hand turn. You can get it to lock when you want though.
    If I had to choose dealing with the nuissance of the front locker or having an open front I'd still choose the front locker. Maybe when I'm forty I won't want to deal with that but as of right now it's a small price to pay for the superior traction in the bush.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine is beyond noisy at times but I've got 80W-90 in it.
    Still no complaints.
    If I were to drive a locked rig in the snow I would only lock one front hub.
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Why would you only lock one front hub? Wouldn't that mess things around /forums/images/graemlins/confused.gif
  19. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    its just like having an open diff, all it would do is deliver power to the tire that is locked, therefore giving you better traction than 2wd and better steering than 4wd locked /forums/images/graemlins/thumb.gif
  20. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Hubs don't like it when the axleshaft spins inside of them without being locked.
    Driving around in 3wd doesn't benefit me any in the snow. It still pulls the truck all over the road. You just know that the only time you'll be fighting it is when you're trying to accelerate.
    I can't hear my rear locker. The front one you can hear and sometimes feel.
