ok i started, now what do i do
Discussion in 'The Garage' started by purple76pearl, Jan 13, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    ok i have a 76 blazer with super lift 6 inch, and some 35's, running a new tranny, with 203 transfew, and old motor, need more power, what gears would i be safe to run in my dana 44 up front and 12 bolt rear, till i can find some better axles, also after relocating my shocks in rear, im needing good shackles to give me more travel? what should i use and where can i get them? whats better with low gears, 400 or 350 motor? im needing general info on this, i drive it everyday, but some weekends when the neighbor takes his new toyota limedted out and runs circles around everyone else, i wanna be right behind him, running with everyone, alos need a good m/t tire, something taht will self clean, and climb on rocks a lil bit [color:blue] [/color]
  2. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Ultimatly you prolly want to get in a 14FF, but the gears are ok up to 4:10, and if you have 35" or bigger Id say 4:56 but the 12 bolt corperate will take it fine, till you start rockcrawling or putting serious power to it. /forums/images/graemlins/thumb.gif
  3. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    I'll trade you a pair of really nice 10 bolts for your POS axles, how about it? /forums/images/graemlins/laugh.gif
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    If your plan is for better axles (like 3/4 or 1 ton axles) then dont waste money regearing your existing 1/2 ton axles. Spend the money on the better axles and rebuild them while driving on your current set. Then just swap them in when ready /forums/images/graemlins/thumb.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I bought a set of 3/4 Ton axles for $250.00 Mine only have 373 gears, but it's alot better then then 1/2 ton axle's 308 gears !!!!!! You can easly find 3/4 Ton axles with 410 gears. Forget the 1/2 ton axles, total waste of time and money to regear them. Get the 3/4 Ton axles, you'll be happier in the long run.
