OK i think i figured out the DEATH WOBBLE.
Discussion in 'The Garage' started by k5freak44, Aug 14, 2004.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    I was getting the death wobble pretty bad a couple of months ago. I replaced the Balljoints and it went away. Now its back.
    Heres what i think it is
    My Sway Bar has a bolt thats not all the way in.
    [​IMG] [​IMG]
    If this couldent possibly be it what else could it be.
    I replaced my tires this sumnmer, new 1s balanced. I got new balljoints and a front end alignment. My schocks seem ok. My stabalizer is 2 yrs old and i think its still ok.
    Anything else?????????????????????
    Anything will help
    thanks guys.
  2. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    try tightening it up and see if that helps, if not unbolt it and see if ti goes away. my 4" lift I had bumpsteered like crazy and I never had death wabble though.
  4. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    I don´t have a Swaybar on any of my rigs and I don´t have any death wobble /forums/images/graemlins/dunno.gif
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    That'd be pretty lame if that was it. A LOT of people don't even run swaybars.
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Same here /forums/images/graemlins/dunno.gif
  7. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    k well then can some 1 tell me how to check the tie rods and what to look for when checking the berrings
  8. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    No shock?
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    tighten the spring plates
  10. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    OK , I have to ask , what is " bumpsteer"
    I probabley know , but have not heard it called that /forums/images/graemlins/blush.gif
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    When you hit a bump and your steering wheel jerks to one side.
  12. big jimmy 91
    Feb 21, 2004
    639
    AHH , thanks
    I did know what it was , just didn't know what to call it /forums/images/graemlins/thumb.gif
  13. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    replace the damper theyre cheap .
  14. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    dude, ur sway bar bushing is shot to sh*t. get a new one and tighten that sucker down! and he has shocks there...its just outta view to the left of his pic. u can see the top of the mount.
  15. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Have some one turn the steering wheel back and forth while you look at the tie rod ends. There shouldn't be any play that you can see. /forums/images/graemlins/thumb.gif
  16. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    yea i got shocks. my damper i got last summer and its a rs5000 so it should be ok. ill check the tie rods. can i check the berrings without opening the hub? if it was the berrings wouldent it wobble all the time? thatnks
  17. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    yup, just get the tire off the ground. and push/pull on the top/bottom. assuming ur balljoints arn't loose (as to my horror i recently found out) it shouldn't make any visible movement. (i say visible cus its gonna move a hair that you can't see)
  18. ugly_blazer
    Apr 12, 2004
    1,214
    jack the truck up so the tire is off of the ground. Put one hand on the top of the tire and the other on the bottom and push/pull at opposite times of each other and see if the tire moves. You could also use a prybar under the edge of the tire, you want to exert more sidways force than up force. If there is movement, have a friend watch for what is moving to verify that it is the bearings loose and not a bad ball joint.
  19. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    see? thats two people telling u how to check it. lol. /forums/images/graemlins/rotfl.gif
  20. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    How is your 'toe in' adjustment on the tie rod? With those big sticky IROKs, if the toe in is wrong, the tires will fight each other big time.
    Mike
