ok...i wanna do a sm465 swap.
Discussion in 'The Garage' started by bryguy00b, May 16, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    id like to start gathering information on doing a swap from a 700 to a 465. i realize that its not easy either. but i wanna try..and i think with ur guyses help and with my dad i can pull it of. but id like ot get some info about it and whats involved. what parts ot look for..im thinking a junkyard someplace or something with the tranny, bell housing, and all the pedals/linkages.
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Do a serch, this topic has been talked about a lot on here.
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    1.Bellhousing
    2.Flywheel
    3.Clutch Disc.
    4.Clutch Cover
    5.Clutch release lever, [fork]
    6.Bolt's, fastener's for all of the above.
    7. SM 465 Tranny
    8.High Hump for floor, with hole for shifter
    9.Shifter Boot
    10.Crossmember for 465 and whatever T-case
    11.Shorten/Lengthen driveline's
    12.Under Dash linkage and pedal assy. [plus all fastener's]
    13.Gear Oil
    14.Lot's of time, [ a precious comodity]
  4. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    I recommend getting hydraulic clutch junk...will make your life a lot easier. I'm pretty sure '85 was the first year for it.
    But yes, EVERYTHING you need to know is already here. /forums/images/graemlins/thumb.gif
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea this is something i was thinking about doing over the summer if i have the money.. for now i wanan suck in as much info as i can get to the point im ready to do it...ive just always wanted a stick. my dad did a a 4 speed swap from a power glide in his 64 impala..so hes got some experience with this sort of thing to.
  6. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    (homer voice)... uhmmm 465... (homer voice)
  7. angrysnowplow
    Jan 8, 2002
    502
    MA
    I hear the worst part is swapping the pedal assemblies. Shouldn't be all that bad if you have experienced help.
    *Disclaimer- I haven't done the swap yet, but I've spent hours and hours reading about it here. So naturally I ASSume I'm an expert. /forums/images/graemlins/thumb.gif
    Just type in '465 swap' and you'll recieve approximately 56436746354 hits /forums/images/graemlins/thumb.gif
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    do the pedal swap first.
    as this doesnt effect the driveability of the truck you can do the pedals long before you do the tranny swap to break the job up.
  9. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    YOu have a PM
