OK it's not the Batt...Red top making a burping sound...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyfumes, Aug 30, 2003.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    OK it\'s not the Batt...Red top making a burping sound...
    I had the wife start the truck and it's not the battery , but instead it sounds like it's coming from the firewall, maybe the heater core, sounds like it's bubbling almost..... /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    Is it just venting gasses, it was deader than dead and I charged it and now after I shut the engine down, I can hear it. I'm assuming it's doing it the hole time it's running. I've only ran it around the block and started it twice for a second after that to make sure it held a charge. Do you guys think it will eventually stabilize and stop burping or is it something else??? /forums/images/graemlins/1zhelp.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    x
    x
  3. chevyfumes
    Feb 24, 2000
    38,584
    266
    Re: Red top making a burping sound...
    How dangerous is it?? should I go put the tunes and lights on for awhile or just run it and not worry about it, I don't think I overcharged it and if I did , not that much...
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    x
    x
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Re: OK it\'s not the Batt...Red top making a burping sound...
    How bad is it burping? The battery on my 84 gurgles from time to time after I shut the engine off and I've had that battery for 6 years now.
    Oops, missed the edit. /forums/images/graemlins/crazy.gif
    Sounds like you've got some air trapped in your heater core.
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    I think I got it all worked out of there, thanks guys... /forums/images/graemlins/thumb.gif
