OK I've been watching too much TV and now have a dumb question
Discussion in 'The Garage' started by mtnman210, Feb 19, 2006.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    On Extreme4x4 yesterday they were working on an FJ60. When they did they spring over they had to rotate the knuckles. OK no big deal mine have been done however I didn't do it. On the toyota axle they made a shallow cut about 3ins from the knuckle--I guess there's a sleeve over the tube--and heated and rotated that part only. I never really thought about it; I always figured that the knuckles were completely cut off of the tubes,you rotated the whole axle to where you wanted it, and then reweld the knuckels back on the tubes.
    So my question is are chevy axles the same? Do they have the "sleeve" or was I right in my assumption of completely cutting off the knuckle?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The C is pressed onto the axle tube much like the axle tube is pressed into the housing. The C is fully welded and the housing is plugged welded. You can cut the welds and just rotate the C on the axle tube and then re-weld. If you look inside the C from the outside you can see the axle tube, I think.
    Ira
  3. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    I'll go out and take a look. when I get a chance. I'm just wondering how I'm gonna rotate them. I'm gonna have to do it again soon on the project truck and I want to do it this time.
