Ok I've searched, but no answer to my Problem
Discussion in 'The Garage' started by TK5, May 24, 2003.
  1. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    Ok I\'ve searched, but no answer to my Problem
    I know that i must have missed something somewhere, but I have a dilemma. I have a '76 Dana 44 8 lug that I am installing on the front of my'83 K-5. Without thinking or checking I have everything ready to go under and bolted up and ready to go and my tie rod ends will not fit the knuckles. I also forgot I that went ahead put the Flat-top knuckles when I get ready to do the cross-over steering.
    I know that I have seen this posted somewhere that I may need to ream the hole for the GM taper tie rods. Is this correct. Can someone shed a little light on this subject.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: Ok I\'ve searched, but no answer to my Problem
    If you are reusing the old ones and need to upgrade them, I just priced a Tie Rod from Auto Zone for my 'Burb at like $44, that might be cheaper than getting the reaming tool.
    I'm not sure if our applications are the same, just a thought.
  3. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Might sound silly, but, did you install it the correct way?
    My 88 10 bolt had the castle nuts on top, when i changed it out to a 74 d44 they had the nuts on the bottom.
    Same taper, just opposite direction.
  4. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    The top hole is smaller than the bottom. i checked both ways. The knuckles are not the knuckles that came with the 44. the guy I got them from said they were chevy, but who knows. I accept his word.
