OK let me try this agian i need help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pplblazerdude, Jan 1, 2003.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    I have a 88 full size blazer equiped with throttle body injection and recently i installed a throttle body spacer and sence i have installed the spacer the truck has idled higer and the brakes arent as good as before is there anyway i can fix this so i can us the spacer and have every thing back to normal cause it really made a noticable diffrence. Thanks
    /forums/images/graemlins/k5.gif
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    maybe check all your vacuum hoses (just a shot in the dark) to make sure by lifting the throttle body you didnt pull one loose or stretch it or something.
  3. pplblazerdude
    Jul 18, 2002
    242
    Ill do that thanks for the advice.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    If it's not vacuum lines, also make sure the gaskets are all good. If the TBI is sucking in more air than it should, the computer will add more fuel.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Try looking here:
    Here
  6. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Try making your subject line more informative as to what your problem is....like "High idle after throttle body install???" It should help with responses. Also, you can always go back and edit anything in your post, that way you don't have to make the exact same post again. Good Luck!
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You need to install the throttle bracket spacers too....did you do that?
    I've installed a tbi spacer on my truck, and I started it up after putting the tbi spacer on, and the idle was really high. So, I unbolted the throttle bracket (back right of intake manifold if looking at front of engine), where the throttle and tv (for transmission) cables are. Then, put the new-included-in-kit spacers under the bracket and installed the new intake bolts. Started it up...and it was back to the normal idle. When you install the spacer...you lift up the tbi unit (duh...talk about stating the obvious), but that in turn pulls on the throttle cable/linkage and opens the butterfly valves just enough to raise idle.
    The only other thing I had to do for this mod was adjust the tv cable....easy procedure...but I won't go through it now 'cuz I'm not sure if you have the 700r4.
    Hope this helps...oh yeah, and changing the subject line to something like, "tbi spacer problems" would get peoples attention (like mine) quicker.
