OK....let's have a fireside chat about brake line fittings....
Discussion in 'The Garage' started by zakk, Nov 18, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    OK....let\'s have a fireside chat about brake line fittings....
    OK...
    I know that the caliper side of the front is a 10mm bango bolt. what is the fitting that attaches to the hardline?
    I also need to know both ends of the rear brake lines. IIRC, it is a 1/4" line (???)
    If anyone has any help on this it would be really helpful. I might have a line on kustom brake lines for cheap if i can get this info in. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    Specs on my rig: 1977 K5 D60 front, 14BFF rear, 1/2 ton brake system w/ stock rubber lines.
    thanks in advance!! /forums/images/graemlins/thumb.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Re: OK....let\'s have a fireside chat about brake line fittings....
    On almost every brake application the hard line is 3/16" with a 3/8" fitting, there are some hard lines that are 3/16" but use a 7/16" fitting.
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Scott,
    Now why don't you spill the beans about the different thread pitches used, and how they aren't interchangeable.....and if you try they will leak all over the place and eat the paint off your freshly painted 14-Bolt, and will lose fluid all the way to Moab and back...?
    Oh, nevermind....I guess that was something I wanted to say.
    You might want to tell him about the thread differences though.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    interesting....
    so that would mean that Aerofit fittings would not work since they only come in AN sizes or 1/8 and 1/4" sizes (for what i am doing anyway)
    is there a way to enlarge the threads? use a different block in the rear?
    suggestions?
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Are you sure that someone didn't sell you a metric brake line? /forums/images/graemlins/shocked.gif
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I think it was more of a 37* vs 45* thread pitch....something about a military thread vs. standard or something like that....?
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Those angles sound like the flare at the end of the tube. There are two different angles for flaring a hard line. I think those are those numbers. But then again, I could be wrong. /forums/images/graemlins/tongue.gif
    Just throwing out ideas /forums/images/graemlins/pimp1.gif
    John
  8. Grim-Reaper
    7,385
    Atlanta
    Just get some hose and a radiator clamp.
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    As i recall, the 37* fittings are the AN fitings.
    The 45* fittings are an inverted flare fitting for brakelines and hard lines. It's 45* for male fittings and 42* for female fittings.
    You can get adapters from summit or speed merchant. Theres a section of fittings "Brake adapters" on Pg. 47 of my summit catalog.
  10. ratlover
    ratlover 1/2 ton status
    Aug 5, 2002
    215
    Peorial IL
    Yup, John. 37 and 45 degree(I think hose are the 2 numbers but there are 2) is the angle of the bevel. The thread pitches are all the same to my knowlege since its not the thread that does the actual sealing. But I am sure there is something I am forgeting. Anything I screwed up guys?
  11. Ryan B.
    Jul 18, 2001
    5,693
    CA
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    woot. nice finds /forums/images/graemlins/thumb.gif
