OK.....look at this PIC and guess what's "different"......
Discussion in 'The Garage' started by Greg72, Apr 9, 2003.
  1. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    OK.....look at this PIC and guess what\'s \"different\"......
    Take a look..... see if anything JUMPS out at you when you first see it.
    READY?
    Did your eyes immediately go to the front fender? The reason I ask is because there is something UNUSUAL about it. The opening is about 2" larger all the way around! /forums/images/graemlins/eek.gif
    I'm playing around with a "stock looking" fender but still trying to get the clearance I need. I'm not sure that this fender will give me enough clearance (especially on the leading edge), but it was my first attempt. BTW -> This is NOT a "photochop"....I really did it in metal. All those lines you see are "slices" I made in the fenderlip to allow me to alter it's shape and make it larger. Right now it's all tack-welded with a quick shot of primer just so I could photograph it. Try to imagine a similar thing on the rear fenderlip too.....that will help make it look more balanced.
    Any comments, or observations about this "prototype"????
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: OK.....look at this PIC and guess what\'s \"different\"......
    looks good man, in fact my first thought was you made slits in the fender in anticipation of doing what you did. I didn't think you did it yet! nice.
  3. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    WOW that looks like factory. But does look like
    the ft part of the fender may hit on full stuff.
    Cant wait to see the rear done.
    Keep up the good work.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yeah, looks good...you're plenty high and the rear part of the front fender looks good. But take some more off the front. Make it so that if you were to stuff the tire into the fender, the sheetmetal would look contoured just like the tire (same clearance front and rear, and same round shape). Maybe, starting at the very top, start a curve that goes down and ends about 3" forward of where the fender is currently cut. Make sense? Just my $.02
  5. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Bo,
    Thanks! /forums/images/graemlins/smile.gif
    My goal is to actually find a way to get the "fang" welded back in on the leading edge of the fender.... on the 1st Gens it's the first thing that everyone cuts off to gain some tire clearance.....I think it would be mind-blowing to have 38.5's AND still have those fangs.....it will make people NUTS trying to figure it out.
    Based on this first "prototype" I think I'm going to "shift" the entire opening 1/2" forward. I probably have slightly more clearance than I need in the rear portion of the fender, but as you mentioned....that leading edge is looking tight already.
    /forums/images/graemlins/cool.gif
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Cool Idea. Like cutouts but without the BIG-A$$ fender flares. Wonder if that would work on 2nd Gens?
    -Brian
  7. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    looks awsome dude!! i thought it was factory and you did some funny drawing with a magic marker.
  8. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Steve,
    There's some weird stuff that happens to wheel travel due to the shackle. The tire travels in an arc (up & back) into the wheelwell as it "stuffs" and the shackle and spring flatten out. Originally I thought a perfectly "round" opening that was 38.5" would be perfect, but it became obvious in a hurry that it won't work.
    The other thing that'll mess things up is when the tires are slightly turned....the outer "shoulder" of the tire is a larger diameter, so even if the fender is perfectly shaped for the tires when they point straight ahead, they WILL rub when the tires turn & stuff.
    It's really a tough balancing act... and I can certainly see now why people just "give up and hack 'em" instead of trying to make a fender like this!!! /forums/images/graemlins/grin.gif
  9. heavy4x4
    Aug 28, 2002
    3,270
    Dang dude, you've really thought this one out...all that stuff didn't even cross my mind. /forums/images/graemlins/eek.gif I completely understand how the suspension works, and now that you say it, it makes perfect sense. I guess I was just looking at how it appears when sitting on level ground. /forums/images/graemlins/smirk.gif Keep up the good work - in the end you'll have every reason to be proud of your work. /forums/images/graemlins/thumb.gif
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hey Greg...How 'bout a before shot to compare with the after shot? /forums/images/graemlins/thumb.gif
  11. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Dang! Looks like alot of work! I can't wate to see it when you finish the hole truck!
    The first thing I hacked was the "Fang"...
    Then the front of the rear...
    Then the rear of the 1/4 pannel came off to clean it up after I lost the rear wheel and it tore it up...
    I still haven't touched the rear of the front fender because it rubs the least. I am still having problems with the rear wheels...I am guessing because my truck is sagging a bit and actually has some flex in the rear.
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Looks the same to me /forums/images/graemlins/confused.gif /forums/images/graemlins/rolleyes.gif
  13. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    My eyes immeadietly went to the lawn chairs /forums/images/graemlins/crazy.gif
    Thats a fine set of chairs you have there /forums/images/graemlins/1zhelp.gif
    Oh yea.. the fender looks great man /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  14. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Joe,
    Here's a "before" shot.....
    Honestly, it's still not a true "before" shot....the fender is hacked (front and rear) to clear the tires below the bodyline. However, you CAN see the upper part of the fender arch is unmolested, and clearly is not proportional to the tire underneath.....
    I wish I had taken some pics when the tires first went on and the fenders were completely "stock".... things were really tight with that setup!!! /forums/images/graemlins/eek.gif
  15. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    You know......the more I look at these pictures side-by-side, the more I'm tempted to lower the truck about 1"!!!
    With that new fender design, I really don't need 4" springs....3" would probably be enough. /forums/images/graemlins/deal.gif
  16. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It really looks like the fang is going to take a bite out of the tire when it flexes with the wheels turned... Could be that the pic is deceiving though. Looks great though, i didn't know that you were a bodyman too! /forums/images/graemlins/thumb.gif </font>
  17. Ryan B.
    Jul 18, 2001
    5,693
    CA
    looks good Greg. /forums/images/graemlins/thumb.gif
    Maybe i'll have to visit you when i stuff some bigger meats under my first gen.
  18. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    You are an ANIMAL!!
    Nice work brother! /forums/images/graemlins/usaflag.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  19. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    It almost makes the tire look too small. Don't lower it, just go w/ bigger tires!!!! BTW, nice sheetmetal work.
    John
  20. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    First off... GREAT WORK!!!
    Second, how about making the wheelwell just about an inch or two longer. Keep the current arch, just extend it in the middle. Make sense? You could even take an inch out of the back of the fender and an inch out of the front, the add those 2" back in the middle.
    KP
