OK.. Need welding help... - Question-
Discussion in 'The Garage' started by reddog64, Jan 5, 2003.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I'm trying to weld... I can weld thick to thick great.. but when I try to weld the sheetmetal (18 guage) to the support beams I just burn holes in it.... I have turned it up and down 1 through 4... and adjusted wire speed... it either goes spit spit spit or burns a hole in the dang stuff...
    Then trying to weld the 18 guages to 18 guage it does the same thing... It's a 110 volt mig.. this thing lays down nice 1/4 inch beads... but cant get it dialed in to do 18 guage... wtf.... /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif and now I need a new pair of gloves... and a new un burnt knuckle... /forums/images/graemlins/angryfire.gif
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    18 guage is a challenge for an experienced welder, especially if you are trying to butt weld it. The best way to do that is to tack a backing plate on one side of what you are trying to weld, then put the but ends together and weld them that way. The backing plate will help prevent blow through and slow the warpage down some.
    John
  3. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    BTW, welding thin to thick is easy, you apply the weld to the thick and bleed the puddle over to the thin. You don't weld to the thin directly or it will disintegrate before your eyes and you will not get any penetration on the thick to hold anything. Sometimes you have to have fat welds....
    John
  4. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    Set the box on the lowest heat setting and then practice running beads on a single piece of scrap. adjust the wire feed until a stable arc can be made. you might have to move pretty fast to prevent burn through. Also check the wire size - you should run small stuff like .024 on sheet metal.
    what model welder is it? using flux core or gas?
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    John nailed the thin to thick.
    Thin to thin is a challenge. Penetration is never an issue because you're always fighting too much penetration. I do a series of small tacks...pull the trigger for 2 seconds and wait for 3-5 seconds and do it again. one tack overlapping the next until it becomes a longer weld. Then move somehwere else and do it again...keep skipping around from spot to spot until it's all welded. I usually stitch weld patches unless they're structural. Weld an inch, skip and inch...then use a good quality sealer over the seam of the repair.
    Most important is a tight fit between the two pieces and clean bare steel. Any gap or crud will promote burn through. Use vise grips, or the handle of a hammer to keep the gap tight.
    Rene
  6. reddog64
    Nov 9, 2000
    3,325
    Thanks Guy's! /forums/images/graemlins/thumb.gif
