OK... next important question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Sep 9, 2001.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    OK... man this is turning into a little nightmare!
    OK, my timing indicator (the little thing that bolts to the timing cover and indicates 0 deg. etc.) is not for a 350 engine... it is too small.
    well here is my debate, I am wondering how common of a part this is (whether or not my local parts stores will have it), or whether I should try to modify the one that I have... now I have looked at this thing, and if I were to cut it, and then bolt it together I can get it really close...
    now this would be a big project, but I don't really want this project to get behind too much...
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Most chain parts stores (AutoZone, Checker, etc.) will likely have one - look in the chrome accessories section.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    well, good bad or whatever I ended up cutting the thing, flattening everything really good, and making where it should be... I then used some JB weld to put this thing together so I'm crossing my fingers and hoping this will work. [​IMG]
    if this does work it will save me some pretty good time in running for parts tomorrow... my heads arrive tomorrow so I am trying really hard to get everything else put together before then...
    with a little (I man a whole lot) of luck I'll be putting this thing in tomorrow night. now I don't hope to have everything hooked back up by then, but I do hope to have the thing sitting inside the engine compartment...
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Cool deal!! JB Weld should hold with no problem - if it doesn't hold, they don't cost more than 4 or 5 bucks.
    Clean up on aisle 3!!
