ok next question. Stud removal
Discussion in 'The Garage' started by stoney126, Aug 27, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    ok got the arm off, seems i just need to give it a lite tap. anyway how do I remove the studs? Im using a superlift block which comes with new studs. Thanks for the info
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Some heat and a good pair of Visegrips.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Double nut the studs or use a stud remover.
    Use a torch to heat up the knuckle at the slightest sign of binding up. Plus some penetrating oil.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and some more penetrating oil...
    i've also had better luck with penetrating oil if you spray it on, then take a good sized wrench or something and tap on the studs/bolts pretty good. the vibration is supposed to allow the penetrating oil to penetrate the threads better.
  5. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    cool thanks guys. Where can I get a stud puller ?
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Auto parts store, tool man, maybe sears.
