OK, next rookie quesiton
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ArrowheadK5, Jan 11, 2002.
  1. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    Since I hope to someday lift my truck 4" or so, would it be prudent to go with 33" tires now to avoid buying them later? Will they fit on my stock K20 until I lift it (godwilling)?
    "They couldn't hit an elephant at this dist..."
    - General John Sedgwick (1813-1864), last words
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    your going to have some rubbing... I'd run the 33's, and do a little fender trimming so you don't get rubbing. then when you do a 4" lift you can run 35's with that same fender trimming after you run your 33's out...
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  3. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    Even without any major off-road stuff, it would still rub? Mostly street.
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I don't think there is a definitive answer to your question. There are two major consideriations, the condition of your present springs and the actual size of the 33's you want to run. My '90 Jimmy wouldn't run 33's at all, yet a friend with an '89 Blazer runs 33's with no lift and no trimming and he runs it pretty hard.
    Derf00
    1990 K5 Jimmy 350 Edelbrock Performer TBI, 6in BDS Lift, Dana 60, 4.56, Corp 14B Detriot, 16x10 AE 589's, 37x12.5 SSR
  5. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    I see what you are saying. Makes sense. Thanks
  6. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I had 33's on my 1990 3/4 ton Sub with no lift and only the slightest fender trimming (about an inch behind the front wheels. If you're going to lift it later I would definately do it. I would also go with atleast a Mud Terrain if you're going off road at all. Why spend money on tires twice. BTW my Sub is up to 6" now and it still has the 33's. I'm getting the 36's soon.
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I'm running BFG's 33x10.5x15's and that k5 never see's offroad! I get rubbing with that if I'm making a u-turn, and I hit a small bump. (and thats a narrower tire then most people run with 33's)
  8. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    but Jeff- WHOSE doing the rubbing while your making a U-turn? LOL the way you typed that is some funny!
    I had- what GY calls 305/75/16's-- which are equal to a 33 on my 94 suburban- on rubbing no trimming- BUT NO NONE NOTTA ZIP off-roading- I could bank on a interstate off-ramp no problem though LOL kids loved that!
    with the K5, right now its sitting on 33's with the 4 + 3 lifts, they look TINY! no fender trimming there, but the body lift helps..
    Brandy
    LOVING the new Duramax!!!
  9. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I don't know but in the last 40 hours I've had 2 hours of sleep - and some people may do well on that but I don't. [​IMG][​IMG]
  10. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    The way my truck sitis now, it would probably rub on the left side and clear on the right!
  11. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The tire game defininately depends on the rig.
    Take mine as an example.
    I have a worn out 3 leaf front spring pac and a 9 leaf rear.
    When I got my 33x12.5's I had no troubles on the pavement.
    The first time out I had to beat in the corners with a 4lb hammer.
    That was on stock 8" rally wheels.
    I now have 10" wheels with 4 1/8" B/S and have not had to do any more trimming.
    *sighs* still running on 33's
    <font color=green> Too bad ignorance isn't painful </font color=green>
