Ok not that this hasnt been asked already.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by burnt_tohst, Jun 24, 2000.
  1. burnt_tohst
    burnt_tohst Newbie
    May 5, 2000
    I know this is a common question. Blame the newbie!!!!!! How in the world do I get the top off. I read and tried to use the info in the posts. The two rear bolts on my Jimmy are some sort of star looking pieces of sh**. I have an '88 Jimmy.
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Those would be torx head screws. Go to your local sears, and invest in a 10 buck set of torx wrenches. Take all the other bolts out. lift up with your back, have friend set 2x4s between the sides and cap so yall can get a handhold then grab it on both sides and walk it off. Set it behind the house and cover it up with lots of crap. Go topless year around, it's the cool thing to do.
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  3. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    dont forget about the hiden bolts they can fu@k you up
    [​IMG]Go prepared
    </font color=red>90 k5 soon to be big, bad, and mean
  4. Adrock
    Adrock 1/2 ton status
    214
    Marlboro, MA
    it might also be a good idea to moisten the gasket between the top and the bed rails with some WD-40. just in case, it might be all dry and nasty and get stuck to the body and rip, which would be bad i guess. just a suggestion.
    Adam
    a.k.a. Adrock
    88 Chevy Blazer FI 383
    Aint nothin' like the sound of Chevy Thunder
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You can also use a Allen wrench for those torx screws.
    [​IMG]YEEEE HAWWWW[​IMG]
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Like Adrock says moisten the seal, I use 409 cos it doesnt leave any oil. Then replace the torx with regular bolts.
  7. laketex
    6,220
    North Texas
    Allen wrench? Yeah you can also use a flat head screwdriver as a phillips too, but you strip those heads out and you'll be hating it. Get the torx set, chances are you'll find some more torx stuff on your truck as time goes by. Personally, I like using torx for mounting stuff in my truck, since most common theives don't know what to do with it...
    [​IMG][​IMG]
    Durant, Ok
