Ok, now I am getting pissed - Valve cover gaskets
Discussion in 'The Garage' started by Topdown, Sep 13, 2003.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok... so, this is the second set of valve cover gaskets I have had on my new engine. Both sets have "sucked" in between the valve cover bolts and along the back. Its really pissing me off.
    What can I do other than RVT them on there? Is there a "best" set to buy? rubber? cork? (both sets have been cork)
    Do I need to scuff the bejeezuz out of the gasket seat on the valve cover?
    Help...
    -Ryan
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I gave up on using stock or stamped steel valve covers years ago. I use a cast aluminum cover with a Fel-Pro rubber gasket with zero leaks. It is nice to be able to tighten the cover down and not distort the gasket sealing surface!! /forums/images/graemlins/thumb.gif
  3. ccox7
    ccox7 Registered Member
    Jul 24, 2002
    69
    Bayou State
    I use regular fel-pro cork gaskets.First I take sandpaper and clean the hell out of the mating surface on the valve cover.If the bolt holes are caved in from overtorque , I take a ball peen hammer and straighten them out til flat. Then take some 3M weatherstrip adhesive and glue the gasket to the valve cover.Next I clean off the engine side mating surface with brake cleaner. Use no RTV , its not needed. Once valve covers are in place, gently tighten bolts down, do not overtorque.These bolts do not need to be Gorilla Tight !! Also make sure your PCV system is working good or you will have nothing but leaks.
    Another trick you can do is buy some valve cover hold down plates that spread the load out along the valve cover and prevents the overtorque problem that causes leaks.Also Victor makes a cork gasket called tuff cork. They are very good as well.
    Hope this helps.
  4. 6869704x4
    6869704x4 Registered Member
    Aug 1, 2002
    42
    NW Fla
    I go one step further and put anti-sieze on the bottom of the gasket. Worked with cork or rubber. Makes it easy to get off too.
    I still get oil seepage around the pcv and oil fill grommets.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree...and I got a cheap set of aluminum too!
    With stamped covers though, I always used 3M Weatherstrip adhesive to glue the gaskets to them as well. Make sure they're straight, use a hammer if necessary. Use the load spreaders as mentioned.
    I am using thick cork Fel-Pros right now with aluminum covers and no leaks except for the hole in the oil pan. /forums/images/graemlins/smile.gif
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Ok, sounds like the gasket is just rolling under or sliding off when you are installing your valve cover. I use a "Spray Tack Adhesive" to hold the gasket to the valve cover during assembly. Makes it much easier to install with no more leaks /forums/images/graemlins/thumb.gif
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    A little tip a pro race engine builder told me was to use a little WEATHERSTRIPPING ADHESIVE(yes you read that correct) does major wonders, dries really tacky and it doesn't leak. I've had this set of gaskets on mine for a while now and now a shred of leakage signs /forums/images/graemlins/thumb.gif
