OK, problem solved, now just have a question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ArrowheadK5, Nov 22, 2001.
  1. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    Why is the fan on my 87 K5 so much smaller than the one on my 87 K20? Both 350s. Alsoo the K5's fan has fewer blades. I have that in the K20 now, until the wrecking yards open up, seems to run cool enough. But why are they different sizes?
    PS--this morning I was able to slide the fan out w/o removing shroud, just like you all said. I guess I just needed to see it in the daylight.[​IMG] Thaks all!!
    The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants.
    --Thomas Jefferson
  2. Grim-Reaper
    7,385
    Atlanta
    K5 is half ton. K20 is 3/4 ton. 3/4 tons since they are a heavier duty truck are geared more towards handling weight. extra weight means the engine is working harder. Since it's warking harder it's generating more heat. So they put a fan on it that will move more air. Since the K5 is more of luxury type ride they put a fan on with fewer blades because it's quieter.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I think that the "standard" GM truck fans are 5 blade designs, while the "heavy duty" fans are 7 blade designs. There are also different size clutch fans. The ones for heavy duty applications are much beefier than the standard ones.
