ok, really dumb math question... need help.
Discussion in 'The Lounge' started by colbystephens, Jan 26, 2007.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i can't remember how to solve more than 2 simultaneous equations. how would i solve something with the following form:??
    3x+4y+2z=0
    2x+18y-5z=3
    5x-2y+8z=9
    what are x, y, and z.
    this isn't an actual problem i have, so i don't care about the solution to that one (if it actually exists), i just want to know what the process is for solving three simultaneous equations. i feel so dumb for not remembering this.
    thanks!!
  2. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Please (Really) Excuse My Dear Aunt Sally.
    1) Parenthesis
    2) Root
    3) Exponents
    4) Multiply
    5) Divide
    6) Add
    7) Subtract
    (In that order.)
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Solve the first equation for z, then input z into the second, solve for x or y, then input (whatever variable you solved for) into the third equation. Repeat until you have solved for all three variables.
    Pretty sure that's how it works. I was going to solve your hypothetical equations, but I lost interest very quickly. Has been a long time since I had to do math like that.
  4. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    the last 3 letters in the alphabet.....:doah: :doah: :doah:
    :haha: :haha: :haha:
  5. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    the process is
    1) Isolate a variable
    2) the resulting definition for the variable will be combination of two other variables.. but that doesnt really solve the problem
    or
    Set two variables to zero and solve for the third... then graph it on and x/y graph
    math is made up of truths...you cant make up things where there are no solutions... you cant use the equations with each other because they have no relation.. what is x in one and y in another doesnt mean anything... they arent related unless you are given some information to relate them.. how does a person with two feet wear three shoes... it makes no sense...there has to be a way to find the value without the variables.. otherwise you will always have an undefined variable... you can set them to zero and put them in a coordinate plane.. but thats for each one and they dont relate
    if Im wrong.. show me
    or ask my wife.. shes a genius...literally
  6. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    solve it as a matrix turn it into a matrix and then solve it
  7. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm aware of these definitions, but this isn't what i'm asking.
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    you can't solve for z - you won't get a value, so you'll still end up with two variables in your equations
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    you can use the equations w/ eachother. take this example:
    3x + 4y = 0
    5x + 2y = 1
    multiply the whole second equation by two, and then subtract it:
    2(5x + 2y = 0) this becomes 10x + 2y = 2
    then subtract that from the first equation:
    3x + 4y = 0
    -(10x + 4y = 2)
    _____________
    -7x = 2
    from here, solve for x, then plug it into the equation for y.
    now, how do you do that w/ three equations??
  10. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    EXACTLY CORRECT.
  11. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
  12. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    The general answer for three equations is.. you cant... unless you set a variable... you can graph them as coordinates by,in each equation, setting two of the variables to zero and solving for the third and graphing that point..
    if I understand the gaussian method he did just what I already described.. eventually setting two variables to zero... if so it doesnt explain the steps to a solution for the original problem as presented by colby.. I believe I am still correct in my assessment
    but this is getting beyond my pay grade... Im still working on the radii/length/stretch of bending, using different size dies, .125 aluminum for a custom center console for my new dodge... now thats math that really means something to me
    cam
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    nope.
    can some one explain the matrix way of doing it? i'm not familiar w/ that way at all.
  14. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Close, but 2x0=0, not 2.
  15. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    This is correct. In your example, I solved 3x+4y+2z=0 for z=-3x/2-2y. I then plugged the value for z into the 5x+2y+8z=9 to get it in terms of x and y, which got me 19x/2+28y=3. I then solved this equation for y=-x/2-14/9. Now I have y in terms of x and can solve from there.
    I ended up with x=419/81 y=671/162 and z=-2599/162. To check your answer, plug x, y, and z into any of the equations and it should work out correctly.
  16. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Thanks for saving me the math. I was just about to sit down and write it out.
  17. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, i'm blind. thanks. oops. :)
  18. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    There is a way to do it where you can mulitiply each coefficient of the same variable by the least common denominator and subtract one equation from another to give one equation with only two variables and go from there, but I find the above way a bit easier to follow and harder to accidently mess up the algebra.
  19. 54inches
    Feb 9, 2004
    1,535
    Houston, Texas
    Like I said, YEP!
