ok, so I got another question still
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Sep 5, 2001.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    OK, what exactly does a rev limiter do??? I am assuming that in some way it limits how high the RPM's can go... is this true???
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    You got it man. It electronically stops your engine from reving beyond a certain point...usually decided by plug in modules. More for drag cars, but they can come in handy in a truck too.
    '73 K5
    Chevy good...Ford bad
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yep, what most rev limiters do is cut the spark to a couple of cylinders at a certain RPM...Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    well the reason that I am asking is when my tranny was going out it was shifting into lower gears at RPM's that were way to high... it was spiking my engine, and with a rebuilt engine in there I'm planning on doing something to control that.
    I was kinda looking at the crane fireball that comes with rev limiter &amp; coil... I'm kinda wondering if the 'rev limiter' as the docs say is really a rev limiter, or something to retard the timing etc... I'm gonna call crane and see what they've got to say.
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I now that in the ones like for NASCAR. It shuts down spark...There might be diffrent kinds...Dan
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea there probably are different kinds... I definately want something that will shut things down where I want them... I'm gonna have to find a solution, but it isn't too aweful critical for now (gotta get the thing back on the road first... [​IMG])
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I was just sitting here going through my summit racing catalog, &amp; they have an accel kit with coil &amp; ignition, and the advertise it as having an <blockquote><font class="small">In reply to:</font><hr>
    'intelligent' rev limiting which lets you dial in top RPM without installing chips
    <hr></blockquote>
    man I had an accel coil and that thing really kicked butt... I'm gonna check out the crane system and if I don't quite like it then this sounds like a good solution.
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Being that your an off roader you might want to consider the MSD 6 Offroad Box. It is totally water proof and vibration proof. It has a rev limiter box that you can buy seperate too. It's more expensive, but it and it connections are waterproof. I have the box in my Jimmy and I love it.
  9. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I would think that is an awesome idea except I got 2 k5's, and the one I am concerned about is my on-road one so I don't know how much those features would really help me... [​IMG]
    yea you're right I got the addiction bad!! LOL
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The MSD 6A box has a built in rev limiter, and there is an ajustachip that you can program to any RPM. The 6A box is cheaper than the Offroad, and I think the chip is $25. The box and chip will be on Jegs, or Summits website for exact prices.
  11. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    well I already got the 6a box (was going to put in the Insane Ewok) &amp; put something else in this one... would appreciate it if you would elaborate on this chip you are referring to, and how the install goes???
  12. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The Accel kit looks really impressive, particularly the fact that it is a direct plug-in installation - I hate cutting into wiring harnesses on later models.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  13. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    oh I tell ya what I really have something against cutting into wires if I do not have to... must be something out my industry (voice telecom) &amp; wiring high capacity digital circuits...
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    From what I read on it the chip is a replacement for the MSD chips. It looks like the MSD chips and plugs in to the same spot except that this chip is ajustable to different RPM's that way if you need to change the RPM limit you don't have to go buy more MSD chips. If you don't plan on changing the RPM limits on your truck it probably wouldn't be worth the money. The Jeg's or Summit website would probably have more info on the chip for you too.
  15. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've avoided late model harnesses ever since I spliced a 3rd brakelight into my 92 F150, and somehow added just enough resistance to have a never-ending trouble code from the ABS.
  16. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    hey thanks again for the info! I'll have to call and find out some details and maybe get one on order! could be exactly what I am looking for &amp; have a lot more reasonable price [​IMG] then the other options I was considering.
  17. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    [​IMG] LOL... man one of those 'hard' lessons??? hey I'm really good at those! (exampe, recent fire experience [​IMG][​IMG])
  18. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    The Crane setup is a real rev-limiter, I used to have a HI-6 and you just set the RPMs and thats where it stopped it. Be careful wiring these things up, mine died a premature death due to a bit of jury-rigging on my part.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  19. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    GO WITH THE MSD 6AL. That is the one with rev limiter. The crane ones are junk. The shop I work at use to sell them for about 6 months. Every one we sold came back within 6 months because it was acting up, or the rev limiter didnt work. Alot of guys floated their valves from it. (Thats caused by over revving). We returned them to Crane, sold them the 6AL box, and no complaints yet. I run one in my firebird. I bounce it off the rev limiter all the time comming out of the burnout box. I have a 6000 rpm chip in it, and it limits between 6000 and 6100. BUY ONE, they are 172.95 in Summit.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  20. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    hey thanks for the info... you know anything about the accel system??? that system kinda intrigues me, but I definately hear ya about the reliability of the MDS'... just want to explore my options...
