Ok so I have some more stuff I'm trying to sell...
Discussion in 'Pacific Region' started by mountainexplorer, Sep 19, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I keep collecting too mcuh stuff, and have a bunch of money wrapped up in stuff laying around right now and I need the money more than the stuff... so here it goes.
    NP203 fulltime T-case in good used working condition (will work behind TH350 trans) $50 each
    NP208 part-time T-case in good used working condition (will work behind 700R4 or TH350 trans) $100
    NP205 gear driven part-time T-case (for behind TH350 trans) sorry no adapter or sleeve $150
    700R4 automatic overdrive, 1985 model year, worked but wouldn't upshift, sold as rebuildable core, but could be something simpler to fix it? It has a reman sticker on it and I bought it as a "good runner" to swap into an '84 K5, but it won't shift out of low gear. Goes forward and reverse fine. $100
    Adapter plate in good shape for between SM465 and NP205, figure 8 style, $50
    Adapter plate for 700R4 to NP208 $35
    Complete hydraulic clutch conversion setup for 1985-1988/1991 fullsize Chevy 4x4, includes bellhousing, slave cylinder, pedal assembly, line and reservoir, $200
    Regular mechanical bellhousing for SM465 4spd tranny, aluminum, $25
    Hydraulic clutch bellhousing, aluminum, for SM465 manual, $75
    Steel bellhousing for early year SM465 tranny, $20
    14-bolt full floater 3/4 ton version rear end, complete, 4.56 gears, open, needs one shock mount fixed and maybe a seal, otherwise complete and drove good $200
    TH400 automatic transmission with NP205 T-case, complete setup out of an '81 1-ton 4x4 truck. Good working condition. Comes with both drivelines, crossmember, t-case shifter handle, lines, torque converter. Tranny was an AAMCO rebuild but don't have the paperwork or receipts. Shifts good. All ready to bolt in and run. $800 firm is what I advertised it for locally, but $700 to someone on here.
    8-lug outer conversion with rotors, hub assemblies, external style Spicer locking hubs, caliper mounts (minus the tin dust shields), large bearing spindles, $125 for all.
    Also, a friend of mine has a Dana 60 front for sale. It's complete, a dually version, 4.10 gears, in good shape, $1000. If anyone is interested in that let me know and I'll pass on his phone number.
  2. dabears73k5
    dabears73k5 Registered Member
    Jul 27, 2005
    52
    El Segundo, CA
    is your friend will ing to ship his d60 to 90245 in ca
  3. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    picture of this?
  4. mountainexplorer
    Nov 14, 2001
    4,903
    Sorry, I don't think he wants to ship it. But if you want, I can get you his phone number and you could talk to him.
    I'll try to get pics of the 8-lug outer stuff.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    PM Sent.
    Ira
