Ok so I might be retarded
Discussion in 'The Garage' started by Jeromy Gibson, Jul 19, 2004.
  1. Jeromy Gibson
    Jeromy Gibson 1/2 ton status
    Apr 17, 2003
    127
    Amarillo Texas
    but I thought hummer wheels were beadlocks, and I got mine this weekend and that look just like a two piece wheel. What do I need and where can I get the stuff to make them beadlocks. Thanks
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    they use a poly ring to pinch the tires bead out to the rims outer lip. so you need to get some rings aka runflats.
  3. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    doesn't someone make just a ring with no run flat, I didn't get run flats cause I will only be running 37s for now, and I don't want to bottom them out, or is that not a problem.
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the hummers only had 36's and 37's on thiers so I see no prob there. and there are I believe 2 places that make em.
  5. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    Any one know where to get just the rings at?
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    we don't wnat run flats. Wouldn't want to air down your tires then have them not form to a rock cause of this big hunk of metal in there. You just need the rings for inside there. Damn Ican't think where to get some. www.stazworks.com I'm sure you could get them there. The idea is that when you tighten the 2 halves together it pinches both beads between the rim and this inner ring. Effectivelly its a double beadlock.
  7. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    thanks I will try there, for some reason I thought they came with that.
  8. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    ok I found some rings but they are kinda pricy, I can get runflats for like 10 or 15 each. Could these be cut down to work for what I need. And what would be an execptable pressure to run the tires at. Last but not least what are you suppose to torque the lock ring nuts to.
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    if I remember right runflats are magnessium. Definalty cant cut it with a torch and I dont know about a sawzall/bandsaw. There' is a company out there that makes an internal tube that you air up and it does about the same as the stasworks poly ring, I think they are for std rims not the two piece type wheels. /forums/images/graemlins/dunno.gif
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    tire loc, greg72 is running that style i believe.
