OK, somebody throw me a bone here
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cybrfire, Mar 4, 2004.
  1. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Last night I put together one side of my Dana 44 ball joint on out and I was on a page in the chiltons manual that listed torque specs for upper, lower ball joints and adjusting sleeves. I can't for the life of me find that page back again and don't remember what they were. I believe the lower ball joint is 70 ft.lbs. and the adjusting sleeve is 50 ft.lbs. What is the upper ball joint stud?
  2. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    ummmm i dunno.
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I would venture to guess the upper is the same as the lower. I never use a torque wrench for anything and I've never had any problems. Just tighten the thing down securely without going nuts and I'm sure you'll be fine.
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    lower I think is 75 upper adjusting sleeve is 50, upper nut is 100
  5. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    100 huh. Man I hate that book. Thanks.
  6. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    my chiltons says 100 ft lbs upper and 70 ft lbs lower.
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    From the 74 factory manual-
    upper= 100, plus additional to align cotter, not to exceed 130
    Lower- 80, plus additional to align cotter
    HTH
  8. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Sounds like 100 on the upper. Thanks guys. Note: there isn't a cotter on the lower.
